Old 08-31-2018, 02:59 PM   #1
12v power for 2nd AC
I am working on a second AC install project. I am putting in my bedroom an Atwood Aircommand 15000 BTU (AC-1511W) that is the same as what I currently have installed in the front. Reading the owners manual it says it needs a 12v connection in addition to the 120v connection. Is that necessary? What's that for? Here is a excerpt from the manual.
2017 Georgetown GT3 30x3
Mechanicsville, VA
dbareford is offline   Reply With Quote
Old 08-31-2018, 03:03 PM   #2
A32Deuce's Avatar
Thermostat maybe?
A32Deuce is offline   Reply With Quote
Old 08-31-2018, 03:49 PM   #3
Yeah, the 12 volts is for the thermostat.
If it's a big pain to get 12 volts to the ceiling you can cheat and use a small 120VAC to 12VDC transformer like a wall wart and power it from the 120 volt power. Of course, if the unit is prewired for a second A/C then the 12 volt wiring is probably already there. If it's not then you're likely picking up the 120 volt power from the power panel. Just run a pair of 12 volt wires along with it from the DC side of the panel.
Gotta go campin!
Old 08-31-2018, 04:45 PM   #4
Thanks for the info. I am pre-wired for a fan back there, so I have 12v wires. I will use those. I still have to run the 120v wire.
Appreciate the feedback.
Mechanicsville, VA
Old 09-01-2018, 01:17 PM   #5
DouglasReid's Avatar
If you use it for the 2nd AC you will have to feed the wires to the thermostat location.
My second AC does not have a thermostat, just a three position switch to select three fan speeds a in AC mode and 3 in heat mode. It has a Heat Strip for heat, it is not a heat pump.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 09-01-2018, 01:22 PM   #6
In this case, it sounds like you only have 30A service? If that is the case, you'll need to run a completely different 120v line that will have to be separate from the remaining power supply. You can install a dedicated 120v line by installing one of these:
https://www.ebay.com/itm/Marine-Onbo...AAAOSwhktawMmt
Jim & Pam
2017 Ram 3500, Crew Cab Diesel Dually
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 09-01-2018, 04:40 PM   #7
In this case, you'll need an extension cord plugged into the 20 amp outlet or generator. I've read this can be done to supply 120V service to a replacement, residential make refrigerator.
gfarmcafe is offline   Reply With Quote
Old 09-01-2018, 04:55 PM   #8
Retired JSO's Avatar
I have an additional Dometic non ducted on my small W&P. I ran the 120 volt power over to a cabinet then forward to the fridge area then down to a male 120 volt exposed near the left rear wheel. I then connect a #10 extension cord to that plug and the 20 amp in the pedestal. Works like a charm.Click image for larger version
Retired JSO is offline   Reply With Quote
Old 09-02-2018, 11:59 AM   #9
The 12 volt is most likely to run the furnace if connected to the same thermostat. Stormy
James Storm is offline   Reply With Quote
power
