Old 03-06-2012, 09:21 PM   #1
DesertHunters's Avatar
2 water heaters...HELP
Ok. So we purchased a used 2005 Cherokee Lite 28A in December. We have slowly been getting it ready for our first trip in a couple weeks. We have 2 water heaters. We have the Suburban which was installed by the builder and an Atwood which the previous owners must have put in. I am so scared to try to run them because of multiple reasons:
1. On the control panel (where it tells you your holding tank info, and pump switch is located) the water heater on/off switch was removed completely.
2. I crawled/slithered into the storage compartment to the back of the water heaters and the Atwood is plugged into a 110V plug which has wires going up into the trailer's wall. The suburban has a power cord just handing there not plugged in at all.
3. I see no bypass valves or anything like that, just metal wire tubing for all the water areas. I don't know if the water heater are both hooked up or just one or if they will even work...
I will post photos so you all can see what I am talking about.
Paul and Stacy and our 2 girls (10 & 4)
Cammie GSP age 7 and Coco Chihuahua age 5
2005 Forest River Cherokee Lite 28A
2004 Dodge Ram 2500 Cummins Diesel
DesertHunters is offline   Reply With Quote
Old 03-06-2012, 09:23 PM   #2
sherdep's Avatar
that water heater switch on the panel is for Gas operation
Make sure there is water in the water heater before turning on - there should be a switch that you can turn on the water heater when you flip the outside door down (Suburban for sure not sure about the attwood)
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-06-2012, 09:54 PM   #3
photos to explain...
Here are close ups of the front and back of the water heaters.
Name:	Suburban water heater.jpg
Old 03-06-2012, 09:59 PM   #4
and here is the control panel with water heater button completely removed...? and close up of pipes behind them
Old 03-06-2012, 10:08 PM   #5
sherdep's Avatar
from the pictures - you got a mess
I would get the Model's off of each unit and try and download the install / how to instructions for each unit and compare the install notes to make sure they look like they are hooked up right.
your pictures are hard to blow up cause they are small when you click on them
Old 03-06-2012, 10:11 PM   #6
onetonford's Avatar
I would have a Camper dealer repair shop check them out I would be afraid of that mess also I had a used Atwood blow up in my face so I lost a few hairs but didn't get hurt it went to the Dump after that and a new suburban went in its place!!!!
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 03-07-2012, 12:50 AM   #7
I was thinking I need to have a professional look at it. I think the previous owner wired one of the tanks to an external extension cord 3 prong and the other is plugged into an outlet that is wired into the wall of the trailer, but is inaccessible because he blocked the entrance to the undercarriage storage compartment with the additional water heater. I am truly afraid to mess with them. I did download the manuals, and both have switches that the owner should wire to and install. That was not done and the original switch from Forest River was removed off the control panel. {sigh}
