Old 04-10-2016, 02:45 PM   #11
Originally Posted by bob caldwell View Post
Make an adaptor plate out of 1/2" plywood and use the one you've got
I just finished up doing this but with some pieces of hardwood I had here at home. TV is up and operational! Thanks for everyone's Input and ideas!
purple_50 is offline   Reply With Quote
Old 04-10-2016, 04:00 PM   #12
Adapter
Originally Posted by purple_50 View Post
So I'm wanting to hang my flat screen in my new 26dbh with the mount that came with the camper. I'm trying to hang my 32 inch TV and the mount that is provided for the TV isn't big enough to attach to the back of the TV. Has anyone had this issue and what did you do to remedy the situation besides getting a new TV that the bracket fits... thanks in advance!
I like working with metal and I have the tools so I fabricates and adapter out of 1/8 in. alum. Two sets of holes, one set fits TV other fits Mount. I used 3/16 nuts and screws to attach adapter to mount and correct screws to attach adapter to TV.
pdqparalegal1 is offline   Reply With Quote
Old 04-10-2016, 04:03 PM   #13
I work for a major railroad rebuilding track maintenance machinery, we have a fab shop as well so I have the materials and means to do something like that as well.. but like any giddy child... I brought home the camper yesterday and had no patience to wait till Monday to get something made.. haha
Old 04-10-2016, 04:11 PM   #14
Oaklevel's Avatar
Try these.................. ramco-eng.com
On our PUMA In and outside
ID:	104504   Click image for larger version
ID:	104505   Click image for larger version
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-10-2016, 07:16 PM   #15
I ran into the same issue I also have a 26DBH, I ended up removing the original bracket and mounted a very similar but larger metal bracket that was ordered on Amazon. I aligned the top holes of the new bracket about 1 and 1/2 inches below the top of the original bracket and used the larger screws included. The name of the bracket is:
"VideoSecu TV Wall Mount Flush Ultra Slim Bracket for most 19" 20" 22" 24" 26" 27" 29" 32" LCD LED Flat Panel Screen Monitor TV VESA 200mm, 200x100mm, 100mm ML206B 1QG[/B] for about $15.00. There are screws on the bottom of the mount to securely fasten the TV to the wall mount so it would not bounce out. I also ordered 90deg video cables.
I hope this helps.
snash_2016GW is offline   Reply With Quote
Old 04-12-2016, 02:19 AM   #16
I just experienced this with our new 26dbh. The PAW Indusries wall mount and TV mount is a 75 X 75 bolt pattern. I am using a 40" Samsung LED TV which has a 200 X 200 mount pattern. I purchased a 75 X 75 to 200 X 200 adapter from Amazon which works perfectly. However, I did find the 40" a bit too big to hang. I will likely go down to a 32" or something in between if it's out there.
jfender is offline   Reply With Quote
Old 04-27-2016, 11:14 AM   #17
On mine I had to move the mount up about a foot in order for my 29" tv to fit. It's solid wall all the way to the ceiling. I usually take it down and travel with it on my bed. Did forget once and luckily 3 hours later it was still there not even loose.
millerman2brian is offline   Reply With Quote
Old 04-27-2016, 11:38 AM   #18
Tom48's Avatar
So I provided for the TV isn't big enough to attach to the back of the TV. Has anyone had this issue and what did you do to remedy the situation besides getting a new TV that the bracket fits... thanks in advance!
If you are saying the bracket cannot handle the weight, that is time to get a bigger bracket, but since most tvs now are so light now that about any bracket can handle it I will assume you mean the VESA bolt pattern is too small for the new TV. In that case MaxQ metal products in Ontario, California is the manufacturer who makes the brackets used in our local FR plant. They have an adapter plate that will bolt to the 75mm or 100mm plate on a small bracket and allow a bigger bolt pattern. They told me it was an $8 option so plus shipping? it might solve your problem. Their web site is a little rough and they told me it is being rebuilt, but they are great to do business with. And wait for it-----it is Asian owners who proudly boast that their products are MADE IN AMERICA. Evidently made right there in their shop. YEAH!!
Tom48 is online now   Reply With Quote
Old 05-03-2016, 10:00 PM   #19
CP3
Question on these mounts. Did all of your rigs come with the mounts for the TV as well as the ones mounted in and out of the camper? Mine didn't come with the one for the TV and our salesman said we have to buy them separate even though the guy that did our walk thru said it came in our welcome packet. If you all got them, I'll be taking a trip down to get it.
CP3 is offline   Reply With Quote
Old 05-03-2016, 10:22 PM   #20
Yes, ours came with the camper in the welcome packet. It was in a drawer under the sink with all the manuals and stuff.
mount
