Old 09-29-2014, 11:35 AM   #11
Ok, I mounted a 32" tv (Insignia NS-32D312NA15) in my Salem Cruise Lite 272QBXL. I picked up a Sanus VuePoint F11c Small Tilting TV Wall Mount at Target for $30. My local Wal-Mart had it for the same price (saved 5% with target debit card). It came with two 1/4x2.5 lag bolts. I swapped them for 1/4x1.25 lag bolts and it worked perfectly (Did not go through & it's sturdy). The mount is pretty low profile and allows you to tilt up and down and also adjusts to make sure it's level even after install. The TV I chose weighs just under 10lbs and the mount locks and lets you remove the TV during transport.
http://postimg.org/image/6c72v4257/
jlgarza15 is offline   Reply With Quote
mount, tv mount
