Old 07-24-2014, 08:45 AM   #1
whiteboycustom's Avatar
272qbxl entertainment tv mount
i know this is a dead horse subjet, i just havnt found much information on the setup i have
the entertainment wall is roughly 1"-1/2 thick, its made to mount a tv on either side of the wall, the tilting tv mount i bought has lag bolts about 2-1/2" long and i just dont know how to mount this thing, i was thinking of buying a second mount and just using a hex head bolt and have a mount on each side and have the ability to put the tv on either side and it not look like poo
2015 Wildwood X-lite 272QXBL
whiteboycustom is offline   Reply With Quote
Old 07-30-2014, 09:57 AM   #2
Well got the tv mounted, had to use 1-1/4" lag bolts, only one went through the other side but no worries I'll buy another mount and swap out the lag bolts for hex bolts and have a mount on each side of the wall
Name:	ImageUploadedByForest River Forums1406732217.339317.jpg
Old 07-30-2014, 11:30 AM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
I have mounted more than one TV in my RVs. I never have used the hardware the mount came with. Come to think of it, in all the TVs I have ever mounted or assisted in mounting I have only used the packaged hardware once.
donanddona is offline   Reply With Quote
Old 07-30-2014, 11:37 AM   #4
Sad thing is it was a mount that a rv accessories website sales
Old 07-31-2014, 11:00 PM   #5
shahlaie's Avatar
We have the same entertainment center as you. We had the dealer purchase a TV and install for us when we bought it. The TV swivels around to the bedroom. I have been wondering if it is possible to mount a TV on each side. Not sure if the pocket doors would allow it though.
shahlaie is offline   Reply With Quote
Old 07-31-2014, 11:01 PM   #6
Mine doesn't swivel....so I can put one on each side
Old 09-25-2014, 04:02 PM   #7
I just bought a 272qbxl. How do you like it so far? Also, what size tv did you put in the entertainment center? I bought a 26" inch to have mounted, but if you put in a 32" that might be the way to go based on your picture. Thanks!
jlgarza15 is offline   Reply With Quote
Old 09-25-2014, 04:16 PM   #8
The trailer is great! Does everything I need it for
32" will fit just fine
Old 09-26-2014, 11:29 AM   #9
Quick question. If you mount two mounts using hex bolts, will it interfere with the doors? Thanks!
Old 09-26-2014, 12:43 PM   #10
The doors will close with the mount I have but will not close with the TV on it
mount, tv mount
