Old 06-13-2016, 09:05 AM   #1
Life Is Good - Camping!
30 Amp Furrion Power Twist Lock Issue
I have a 2017 cherokee 274DBH. I can not get the nut/coupling to thread on the inlet power with the furrion 30 A. Dealer said push hard and it should catch. Any suggestions It is brand new.
Thank you,
drz123z is offline   Reply With Quote
Old 06-13-2016, 09:28 AM   #2
Thank you,
Those connectors have too fine of a thread, and they're notorius for getting cross threaded or stripped.
Mr Havercamp is offline   Reply With Quote
Old 06-13-2016, 09:28 AM   #3
grumpy0374's Avatar
Had one now for almost 2 years and never had any problems threading it. I wouldn't recommend "pushing it hard" as you may cross thread it and then you'll have to replace it.
Just apply a little push while turning the nut. I have found that the threads must be clean...don't allow any dirt to build up in the threads.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-13-2016, 03:42 PM   #4
Who Dares, Wins
doc73's Avatar
I have also found that I unscrew it a few turns before tightening it, seems to let the threads set I to place and screw on easy. I agree it is WAY to easy to cross thread.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 06-13-2016, 03:50 PM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
Make sure cord is level and straight when trying to attach nut coupling. Cord has a tendency to sag when trying to turn nut coupling. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 06-13-2016, 03:55 PM   #6
Pickin' & Campin'
Those rings can be a real bugger to get started without cross threading.
If by chance the ring has been damaged, (cross threaded) your only hope is another end or a new cord. Hopefully the socket on the side of your rig isn't damaged too.
Like mentioned above, I hold slight pressure on mine while UNSCREWING (righty tighty-lefty loosey) to set the threads/ring to the proper position and then tighten slowly and easily.
Works every time with no problems.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-14-2016, 08:59 AM   #7
Head Rambler
I too back if off a little until I feel it 'click' then easily turn it clockwise until the threads catch. It'll usually thread right on then.
Gotta go campin!
Old 06-14-2016, 09:07 AM   #8
SeaDog's Avatar
Thank you,
Go easy with that ring as other have said turn counter clock wise a couple of turns using both hands to center the ring and then turn clock wise to thread the ring on, there should not be allot of resistance it should thread on easily. Make sure your cord is fully seated and turned clock wise to lock the cord into the receptacle.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-14-2016, 01:43 PM   #9
Thanks I will give that a try. I did notice that the cord itself does not twist once inserted either?? This is another concern as my previous camper I could insert and twist in place to the right and then screw into place to secure the cord. I called and e-mailed the manufacturer Furrion and have been playing phone tag with no results.
Old 06-15-2016, 10:56 AM   #10
My brand new Furrion cord had a broken lock ring. They sent me a new ring free of charge. They are easy to change.
Springerdad is offline   Reply With Quote
power
