having '50amp RV service' is certainly useful, as it is actually TWO 50amp hot lines coming into your breaker box, for up to 100amps of service - certainly a LOT more than the typical 30amp service, as it is truly only 30amps.
If you are wanting to add a second air conditioner, it certainly warrants the change, UNLESS you want to go a less costly route, and add an additional air conditioner with a dedicated 15 or 20amp compatible extension cord that you can plug directly into a 15 or 20 amp residential type outlet, which are usually already available right next to the 30amp outlet. Your new air conditioner size will determine whether you need 15 or 20amp.
You can continue using your coach just as you do now, but you'd have the additional air conditioner on it's own circuit breaker and it would not effect your coach's current breaker box setup. A lot less work.
The Turners...
