Old 02-11-2012, 10:22 AM   #1
30 ckbh rear coax jacks not working
Hello!
My 2011 Shasta 30CKBH rear coax jacks dont seem to work.
Antenna booster on: the living room and master bedroom jacks work but not in the rear of the unit.
Pulled covers in the rear kitchen and back bedroom and the jacks are connected to coax cable. Is there a switch or a splitter somewhere I need to check?
Thank you!
Rich, Steph, Ava, & Micah
2010 Sierra 1500 SLE Z60
2011 Shasta Revere 30 CKBH
RichieD is offline   Reply With Quote
Old 02-11-2012, 10:27 AM   #2
TURBS's Avatar
someone correct me if I am wrong but I don't believe the tv antenna signal goes to the other coax jacks just the front tv.
only your dvd player goes threw them .
unless they have worked before they probably never will with over the air antenna .
by the way does the tv your using in the rear have a built in digital to receive a signal ?
Old 02-11-2012, 10:34 AM   #3
yes, its the same tv i used in the front bedroom. I was not aware that the antenna signal does not go to the other jacks.
Old 02-11-2012, 10:44 AM   #4
TURBS's Avatar
MY last two campers were the same way the antenna only goes to main tv .
like I stated before only your dvd player run back there .
now im sure you could remove your media center and tee into the antenna cable to your back coax .
Old 02-11-2012, 12:38 PM   #5
Thank you for the info Turbo! I am replacing my media center, this will be a good time to tee into the antenna cable for the back coax. Going with the Jensen AWM 970.
Old 02-11-2012, 01:57 PM   #6
TURBS's Avatar
glad I could help !
