30 to 50 adapter ???
I got a call from my friend his relatives Motorhome Alegro something had burned up the end of the power cord with the adapter and the front AC had stopped cooling so they started the rear.
When I got there the rear AC was running, and there was power to both side of the 50 amp breaker. (i was under the assumption that when you added the 30 to 50 one side of the 50 was dead, this was not the case) I turned the breaker off to the rear AC and restarted the front AC which cooled as it should. I did find the Rear AC fan was in the on position and not auto.
The Valterra 30 to 50 supplies both legs of the power panel, I think with the front AC on and the rear fan on it just pulled to many amps and caused the front AC to quit on overload and the plug to burn up because of heavy amp draw. What do you think this is the first time I have run into this.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
