Old 10-06-2011, 02:29 PM   #11
BigDTx's Avatar
the wires for the lights may run along side the wires for the stereo and that is causing electro magnetic interference (feedback) you would need to seperate the wires and install a noise filter in the 12v power lead to the stereo. you can maybe run a new power lead to the stereo straight off your battery with an inline noise filter and bypass the convertor and the rest of the electronics that are causing the interference.
BigDTx is offline   Reply With Quote
Old 10-06-2011, 02:32 PM   #12
BigDTx's Avatar
Electromagnetic interference - Wikipedia, the free encyclopedia
Old 10-06-2011, 02:32 PM   #13
Triguy's Avatar
How good are your dimmer switches, including the one you replaced? Good ones are supposed to have filters in them to help reduce EMI. Cheap switches often do not.
We bought a house with cheap switches in one room and had the buzz. Replaced with good (higher cost) switches and that took care of it for us. Just a thought.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-06-2011, 02:36 PM   #14
BigDTx's Avatar
http://www.forestriverforums.com/for...zzz-17033.html
this is a duplicate thread, I have tried to anwser your question in the other thread.
Old 10-06-2011, 02:47 PM   #15
Herk7769's Avatar
Jumping in!
My standard answer is to check your grounds. Chokes and filters will only work if your system ground is solid. Most of the grounds I found were made by screwing a self tapping screw into a random spot on the frame.
Once the threads start to rust or corrode (almost immediately) the signal starts to get dirty. In my camper the Concertone ground is tied to the frame under the camper's coroplast belly panel. To even check it one side must be dropped.
Radio shack and Cruchfield sell a good filter for a few bucks and if you contact Bob Fields he might be able to facilitate one out of the factory.
American International S-15A (15-amp/250-watt) Power line noise filter at Crutchfield.com
Name:	Horst Probe Install 017.jpg
ID:	8371   Click image for larger version
Name:	Horst Probe Install 027.jpg
HAM CALLSIGN - KC3FFW
Old 10-06-2011, 02:50 PM   #16
MtnGuy's Avatar
Merged the 2 threads.
Old 10-06-2011, 03:01 PM   #17
BigDTx's Avatar
Originally Posted by herk7769 View Post
Jumping in!
X2 what Herk said, check your ground!
Old 10-06-2011, 06:45 PM   #18
well,ive checked my grounds,replaced the concertone,added the very high end filter and the camper is only 9 months old.so,at this point im looking at possibly getting rid of the dimmers,although i think this should be a warranty issue.like i said earlier,the newer model of my unit doesnt have dimmers in it.
triguy,i replaced the stereo,not the dimmer.
cman is offline   Reply With Quote
