Old 04-26-2016, 01:27 PM   #1
36ckts tailgater
This past weekend I tried to connect our tailgater directly into our 36CKTS. I plugged the satellite into the Living room connection in the water line cabinet. I then connected my receiver into the satellite connection in the cabinet door by the LR TV.
I was unable to get it to connect to the satellite and was only successful after directly connecting it to the satellite.
Is this not possible or am I just doing it wrong? Trying to buy some time before purchasing the traveler.
2016 Cedar Creek 36CKTS
2013 F-450
emtp82 is offline   Reply With Quote
Old 04-26-2016, 01:59 PM   #2
bubbles's Avatar
If it works right when directly interconnected what makes you think a traveler would be better with what you have for hookup? It would appear the coax you selected for the receiver is not the right one or there might be a splitter in that line and don't think a traveler will help without modification. Of course the modification would also allow the tailgater to work if there was one.
Old 04-26-2016, 02:07 PM   #3
It's pre-wired for the traveler, to use the tailgater I have to run the coax through a window. I'm hoping there's a way to connect the tailgater without using a window.
2013 F-450
Old 04-27-2016, 09:05 AM   #4
I would check out the other outlets. The Amish build these campers. I found on my Cedar Creek that some of the tv outlets were hooked up wrong, you know the Tailgator works hooked up straight so it's just a matter of finding the right ones. You can ohm it out with a ohmmeter but not me I'm a little slow with those things
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
