Originally Posted by Cariley
Mr. Havercamp,
Finally checked heater elements, reading was 34.8 ohms.
So that probably means they are OK? Any thing else I can check?
I appreciate your help.
Happy Independence day weekend!
Same to you...Happy 4th.
In your original post you mention you lost some food. I assume you had the fridge on auto and when the AC fuse blew the fridge did not switch to gas......which it should. The AC side is not really complicated.....basically just an element and a relay.
I would go to the lower board next per the service manuals and do those diagnostics. Switching parts as a diagnostic can get expensive. Maybe time for a trip to or call in the pros. If it is that board replace it with one from Dinosaur instead of the Dometic replacement.
