Old 05-26-2013, 08:28 AM   #21
Someone may have added the extra 120v cord for a separate heater or appliance. If you could get someone to help you figure out where it goes, it might still be functional. I would put a new plug on the end though:
2013 Columbus 295RL Fifth Wheel
2011 Ford F-250 Diesel 4x4 CC KR
Tim295 is offline   Reply With Quote
Old 05-26-2013, 08:39 AM   #22
VinceU's Avatar
Originally Posted by brat1598
Yellow is the one the one she said is 110 and the black one is the 220 the pics r dark because its dark outside. I can post better ones tomoro
Looks like std. 15/20 amp and 50 amp male connectors. Lot of work to replace a dogbone converter. Can't tell if factory or not. 38' certainly needs 50 amp interesting, like to see CB panel.
Old 05-26-2013, 01:37 PM   #23
So its not sopposed to have both?
brat1598 is offline   Reply With Quote
Old 05-26-2013, 01:45 PM   #24
VinceU's Avatar
Nope, don't think here has ever seen this either. Trick is how to tie to buss with two separate power supplies?
Old 05-26-2013, 05:36 PM   #25
I don't know a lot of terms what is cb box and what is buss
Old 05-26-2013, 05:44 PM   #26
Denver, CO
garbonz's Avatar
Circuit breaker CB.
buss is the metal piece with set screws and hole for wire of the a
Same polarity to go through. In this context, it is the circuit distribution box where the beakers are and it would be very interesting to see how the two plugs are wired. I'm guessing that it is creative and not necessarily safe.
2017 Fuse 23T
Old 05-26-2013, 05:58 PM   #27
Always Learning
It's not that it's it "not" supposed to have both. But it wasn't from the factory with both and it was something that the previous owner added on- either by their own or they had their dealer do it.
Usually with these 120 volt add-ons, they are dedicated to a specific outlet or set of outlets inside the camper. Some people add them specifically for running high electric use items - like space heaters.
That said, you likely do not NEED to use the 120volt connection. Like I said- I doubt anything WON'T work; there will just be some outlets that won't. Your original question still stands- for a 50amp rig, what limitations are there to only having 30amps available? Of which, my original answer still stands.
You will need a 50amp to 30amp adapter like Herk showed.
Old 05-26-2013, 06:18 PM   #28
Denver, CO
garbonz's Avatar
Yep, you are spot on. We just went tech there for a few minutes and forgot the original Q.
2017 Fuse 23T
Old 05-27-2013, 06:53 PM   #29
This is what everything looks like
Old 05-27-2013, 08:05 PM   #30
bikendan's Avatar
that's DEFINITELY not factory.
Old 05-27-2013, 08:08 PM   #31
Oh so what would u advise I do
Old 05-27-2013, 08:13 PM   #32
Herk7769's Avatar
That shore cord needs replacing too; look at that tape on the wire.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-27-2013, 08:14 PM   #33
bikendan's Avatar
i would find out where that 20amp 3-prong cord was hooked into.
that's looks to be some jury-rigged setup, to me.
Old 05-27-2013, 08:24 PM   #34
Denver, CO
garbonz's Avatar
Whew. If you have basic electrical skills or know someone who does, you can..
Replace the plugs on the wires you have.
Chase down where the two wires go and what they power.
Decide what to do.
I personally would be concerned about your wiring till you can figure it out. On the other hand, If everything has worked well in the past, just get a 50 to 30 amp converter and see what happens. Plug in the 30 amp plug and see what works and what doesn't. What doesn't will be the circuit that the 15 amp plug powers.
2017 Fuse 23T
Old 05-27-2013, 08:28 PM   #35
Ty all
Old 05-27-2013, 08:31 PM   #36
Decide what to do.
X2. Nice summary.
Old 05-27-2013, 08:44 PM   #37
Let me make one additional suggestion if you're going this route: Wrap some insulating tape around that 15-amp plug, just in case they've wired them together.
Old 05-27-2013, 09:09 PM   #38
jtstromsburg's Avatar
By chance, the hwh doesn't have an electric element wired directly thru that extra plug? Or an electric fireplace?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 05-27-2013, 09:18 PM   #39
Not sure what that is but we have an extra water heater in the camper
