Old 06-15-2016, 09:44 PM   #1
Retusps's Avatar
A/C and fridge
I was wondering if I can run both a/c and fridge while plugged into my home 110 shore power? 30 amp w/adapter. Didn't know how much power the fridge draws, wanted to run them both to get ready for a weekend outing.
No matter where you go, there you are!
2006 GMC Sierra CC 1500 Z71
2014 Palomino Solaire Eclipse 297rlds
Husky Centerline w/d hitch
Retusps is offline   Reply With Quote
Old 06-15-2016, 10:13 PM   #2
Professional Curmudgeon
The short answer is "probably". Since you'll be traveling anyway, why not run the fridge on propane. The refrigerator is one appliance that is easy on propane.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 06-15-2016, 10:17 PM   #3
raspivey's Avatar
No problem at all. I do it all the time. I'll normally start it on propane for a few hours since it cools down better, then switch it to auto and leave it.
Old 06-16-2016, 01:23 PM   #4
Head Rambler
Are you plugging into a 30 amp receptacle and using a 30 to 50 amp adapter?
If so, then there's no problem running both.
Gotta go campin!
Old 06-16-2016, 01:33 PM   #5
TURBS's Avatar
I take it he has a 30 amp camper and using a 15 amp adapter.
If thats the case I'd not run the a/c and fridge on 120v
Sent from my SCH-R530U using Tapatalk
Old 06-16-2016, 09:11 PM   #6
Retusps's Avatar
Correct, 30 amp with 15 amp adapter. I ran it today and all is good . Should I turn off the fridge? Will it blow a fuse or what? Sorry for the newbe questions.
Old 06-16-2016, 09:37 PM   #7
If it was going to blow a fuse, it probably would have pretty quickly.
Risks: check the extension cord and adapter for heat, I once melted a 30 to 15 amp adapter plugging into my brother's garage and running the air.
Running the air on low voltage can shorten the life of the compressor significantly.
When running that A/C, you'll want to minimize the current draw; don't run microwave or water heater, or even a lot of lights.
Old 06-17-2016, 08:12 PM   #8
Be certain your extension cord, if you use one, is 12 guage. That is rated for up to 20 amps. The house outlet could be 15 or 20 amps. Look at the breaker in the house to know for sure.
I run a/c and fridge together often. My home outlet is 20 amp.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-17-2016, 08:18 PM   #9
Flybob's Avatar
If the fridge heater is on and the AC restarts ( after running then a brief off period) it may trip the breaker in the house if you have it plugged into a house outlet on a 15A breaker. Also what else in the house is on that breaker. For example if it is a garage outlet and both items are running in the trailer and you operate the garage door opener it will trip the house breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-17-2016, 10:46 PM   #10
My Dometic RV fridge draws a little less than 300W of AC power when cooling. This should be around 2.5A at 120V. A 15A circuit would have around 10+A available for the air conditioner which would be a little over 1200W, very close to what it's rated to draw.
Overall, it should work. If the circuit breaker trips when the A/C compressor kicks in, you'll need to move the power cord to a 20A circuit. As already recommended, run the fridge on propane and you'll definitely have no issues running the A/C unit. If you're plugged in at home, you could always run the AC during the day and switch to the fridge at night. This also gives you an excuse to get into the unit twice a day to verify that all is well.
Phil
pmsherman is offline   Reply With Quote
fridge
