Old 08-16-2013, 03:09 PM   #1
A/C blows breaker w/generator on
Using the generator to power the A/C while driving,
with the outside temp 95-100, the A/C breaker blows
after 15-20 minutes. It is set on low.
2006 Forest River Georgetown; 90 hours on gen; 5500 watt
Guardian gen. The AC works fine hooked up to Alt.current.
costello is offline   Reply With Quote
Old 08-16-2013, 03:28 PM   #2
Do you have a volt meter? Need to check a plug and see how many volts is there with the genny running. It may be running a low voltage and increasing the amps drawn by the A/C and then trips the breaker.
Acableguy06 is offline   Reply With Quote
Old 08-16-2013, 03:32 PM   #3
Camping and Racing :)
Black X's Avatar
I'm a newb I know but based on your description I would think that because your running the A/C while driving the air going across the housing is creating a low pressure area reducing airflow across the evaporator. I would assume that 15-20 minutes of this is causing the unit to freeze up and throw the breaker.
Just my 2 cents.
James
TV: 2011 Ram 1500 Sport 5.7L Fuel Eating Machine
TT: 2014 Wildcat Maxx 26FBS
Black X is offline   Reply With Quote
Old 08-16-2013, 03:33 PM   #4
Black X's Avatar
This is a good thought too... Voltage goes down Amps go up!
Old 08-16-2013, 04:01 PM   #5
Tinbender1947's Avatar
Generator p[roblem
Actually if the a/c is freezing up, there will be no air flow inside the coach. And if it is freezing up the amps will drop because of no load on the compressor.
Sounds like a generator problem, rather than the a/c
Tinbender
Tinbender1947 is offline   Reply With Quote
Old 09-05-2013, 11:12 AM   #6
generator
Is your power cord heavy enough so you don't get a voltage drop?
Scott619 is offline   Reply With Quote
breaker, generator
