Old 06-26-2016, 07:26 AM   #1
Ford Idaho's Avatar
A/C condensation question.
Being from the desert where humidity is generally low to none existent I am not sure if I have an issue or not.
Currently in southern Texas, I noticed this AM that water running off the roof is a very steady drip and the cement slab is quite wet.
Is this normal for the area or do I have an issue?
Old 06-26-2016, 07:33 AM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
If you have any humidity your AC will be taking it out. May not be much and that is probably why yours is dripping. I'd say normal. Where I live you can either have high or low humidity and I may not see any water coming from air on low days. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-26-2016, 07:35 AM   #3
shughey00's Avatar
Very normal for any areas with humidity. The humidity does not have to be in the oppressive range either.
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
Old 06-26-2016, 08:41 AM   #4
Ford Idaho's Avatar
Thank You both of you.
I now have a set answer for the boss when she starts asking question...
