Old 08-22-2012, 12:20 PM   #11
Dallas Texas
TexasBBQ's Avatar
Originally Posted by Great Horned Owl View Post
On that thermostat.... It may continue running for 30 seconds or so, but it will turn off.
Joel
Until then get a blanket.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 08-22-2012, 12:39 PM   #12
Triguy's Avatar
Here is the operating instruction manual for the Dometic Single Zone LCD Thermostat.
On page 7, it explains how to set your fan to "Auto".
It goes on to say that, in "cool" mode, when auto fan is selected the fan speed will vary depending on the difference between the temperature set-point and the room air temperature. In auto fan the compressor and the fan will cycle On and Off with the thermostat.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-22-2012, 12:53 PM   #13
travelinfitter's Avatar
Thanks for posting the manual. The dealer did not have the manual for the thermostat in the packet of manuals they gave me. Thanks again everyone for the help.
2011 F-350 King Ranch 6.7 Diesel
2013 Crusader 325RES
travelinfitter is offline   Reply With Quote
Old 08-22-2012, 01:02 PM   #14
Triguy's Avatar
Let us know how it works
The Files section of our forum (above in the green menu bar) has many of the manuals for appliances, etc that you can download if you find yourself needing any others.
Scott
2012 Shamrock 233S
Old 08-22-2012, 01:33 PM   #15
jriddering's Avatar
Hello everyone! I just got my first camper in July. A Crusader 325RES. So far we love it. I'm having an issure with the a/c tho. No matter what temp setting I set the unit runs all the time. I turned it to 90 tonight and it kept running. I have a digital thermometer that says my camper is 70.4 so I'm not sure why it wont kick off. Any ideas?
It doesn't look like anyone is understanding your problem correctly. If you have temp set at 90 deg and it is going to 70.4 degrees, it is not a thermostat setting problem. I am assuming you can shut down the whole unit if you want. Unless I am the one that is confused, it sounds like you may have a wiring problem. Sounds like a 2 wires are touching each other and thermostat can't turn off compressor. I would guess wires behind thermostat could be touching each other, maybe too much insulation taken off.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 08-22-2012, 07:38 PM   #16
Exactly! When I turned the temp to 90 and left it like that for 5min it was still running. Ill take it apart tomorrow and see if I can find a problem.
Old 08-22-2012, 08:24 PM   #17
timarti's Avatar
Had the same problem with our Ultralite 2304s. AC would not shut off, just got colder and colder. Dealer repair notes said "relocate AC/heat thermostat on/off switch, rewire, repair holes in previous location". Not sure why they moved it, but you would never be able to tell if you did not know. It originallywas quite high up, maybe a foot below the ceiling and now is about the level of the fridge handle. Warranty job just after we took delivery.
Tina & Ted & pooches
2012 Ford F-150 XLT 5.0L V8 4x4 with tow package
Andersen WD hitch with sway prevention
2012 Rockwood UltraLite 2304s trailer
timarti is offline   Reply With Quote
Old 08-23-2012, 07:11 AM   #18
jriddering's Avatar
Timarti could be right too. It could be a miswire too. If you don't see anything obvious, it may be time for your dealer to correct it. Also thanks to TRIGUY for instruction manual. I learned how to see the actual temp in camper and learned there are filters in system. Cleaned them last night.
Jim and Carol
Jim and Carol
Old 08-23-2012, 07:21 AM   #19
Read the manual ! I agree with jt
SALTY is offline   Reply With Quote
