Old 08-21-2012, 10:33 PM   #1
travelinfitter's Avatar
a/c doesnt turn off
Hello everyone! I just got my first camper in July. A Crusader 325RES. So far we love it. I'm having an issure with the a/c tho. No matter what temp setting I set the unit runs all the time. I turned it to 90 tonight and it kept running. I have a digital thermometer that says my camper is 70.4 so I'm not sure why it wont kick off. Any ideas?
2011 F-350 King Ranch 6.7 Diesel
2013 Crusader 325RES
travelinfitter is offline   Reply With Quote
Old 08-21-2012, 11:07 PM   #2
On a camper AC, the fan always runs. The compressor cycles when needed to maintain temp, but the fan always runs. It's a design, too lengthy to get in to, but keeps it from freezing up. Kind of like the AC in your car, the fan always runs, but the compressor will cycle as needed. Hope this helps.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-21-2012, 11:13 PM   #3
jtstromsburg's Avatar
In my rig, I can select fan and then adjust to auto, low, and high. Low and high are fan on options. Auto will allow the fan to shut off at desired temp.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-21-2012, 11:15 PM   #4
TURBS's Avatar
When mines set to auto and a/c reachEsther desired temp it shuts off.
If it's set to (on) then the fans run non stop and a/c compresser only cycles .
Old 08-22-2012, 05:09 AM   #5
Which setting is best, auto or on?
RickV is offline   Reply With Quote
Old 08-22-2012, 05:34 AM   #6
RickV
We use Auto, have you checked your filters? Dirty filters can do lots of things...personal experience! Auto is like the a/c in your house..cycles on/off once the desired temp is met.
On will run until you turn it off.
Andi
kidsgone is offline   Reply With Quote
Old 08-22-2012, 07:39 AM   #7
Thanks for all the replys. My thermostat doesn't have an auto option. It just has "furnace, cool, fan hi/low" I have it set at 75 but when I woke up this morning it was 62 in the camper and cold air still coming out.
Old 08-22-2012, 07:46 AM   #8
Think you should get the manual out for the thermostat and read it very carefully. There has to be a way to shut the ac off & turn the furnace on/off and have neither furnace or ac run.
Old 08-22-2012, 07:56 AM   #9
Great Horned Owl's Avatar
On that thermostat, repeated presses of the "On/Off Mode" button will cycle the system through Fan, Cool, Furnace, and Off. When the Furnace LED is showing, press the button one more time and WAIT. It may continue running for 30 seconds or so, but it will turn off.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 08-22-2012, 08:03 AM   #10
I agree-read the manual. I believe by pressing the on/off mode it will show "auto" I know ours does
jmswms is offline   Reply With Quote
