Old 08-16-2016, 11:32 AM   #11
You can check the hold down bolts from inside. Just take the cove off and you will see them. These bolts almost always need to be tightened every few years because the gasket really does compress a good bit.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 08-17-2016, 03:01 PM   #12
Tightened the hold down bolts. Leak got very minimal, and now seems to have stopped.
Thank y'all for the help! Hopefully, that fixed it.
Larry Tiner is offline   Reply With Quote
Old 08-17-2016, 03:30 PM   #13
2007 WildCat 32QBBS
05CrewDually's Avatar
That's great. Thanks for the follow up.
05CrewDually is offline   Reply With Quote
Old 08-17-2016, 03:31 PM   #14
Head Rambler
Thanks for reporting that you got it fixed and how.
Just keep an eye on it, as you may need to replace the gasket if it keeps dripping.
I think the torque for the hold-down bolts is 45 in-lbs (not Ft-lbs).
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-17-2016, 05:25 PM   #15
On my previous camper I had that same problem. I have a friend who does RV repair so I consulted with him. He started smiling the minute that I started telling him my problem. On that Dometic unit there is a little plastic drain piece under the evaporator and the condensate that runs off the evap collect in this drain channel then runs out towards the edges, both sides. The real problem was with the drain holes in the pan that sits on top of the RV. This would allow water to accumulate then run down into the RV. Without taking the wiring loose we removed the unit from the roof enough that he drilled a couple of holes as near the actual bottom of the pan as possible. The allowed the water to run out onto the roof, as it should. I have also seen plans on this forum of a way to make a 3/4" "pedestal" which goes under the rubber roof and holds the A/C unit 3/4" off of the roof. This helps to prevent water from intruding through that infamous foam gasket.
Thurman is offline   Reply With Quote
Old 08-17-2016, 06:03 PM   #16
Thanks, Thurman. That'll be my next move if it ever stops raining....
Old 08-17-2016, 08:37 PM   #17
2007 WildCat 32QBBS
Holy smokes that's exactly what I did to mine today!
I pulled the shroud and got rid of 3 wasp nests first. Then with the unit running I saw the water laying in the rear lip of the pan. Occasionally the fan would blow some out but for the most part it held water.
The issue is the pan drains are designed for a flat roof such as on a tag along trailer. On my 5th wheel (and majority of them) the rear roof is sloped back so the water can never properly drain from the drain holes that are close to the center. The moisture is mostly sweat from the expansion valve tubing going to the evaporator.
So I took a thin piece of sheet metal and slid it between the rear of the pan and roof to use it as a back stop for the drill bit. I then drilled a proper drain hole. Put it all back together and it works great. No more water.
I also noticed the trough drain you spoke of for the evaporator. That was clear and has its own large drain hole so no issue there.
Old 08-17-2016, 08:49 PM   #18
Premature celebration... Rain picked up and was pounding. Water started dripping from ceiling in bedroom. When I turned it off, it briefly flowed freely. Rats!!
Old 08-17-2016, 10:16 PM   #19
May I clarify that the a/c leaks only when it rains and only when it is cycled off after running.
Old 08-17-2016, 11:38 PM   #20
When your fan runs, it pulls a suction (vacuum) on one side of the fan (the return air side). This suction can hold up water from draining. When the fan stops, the vacuum goes away and all the water that's been held up drains out. With low humidity, you may not get enough water to see this effect, but with high humidity you would. If this is happening, there's a problem with your drains.
(The other problem with this is that, since no water ever drains out while the fan is running, you aren't really removing any moisture from the air in the TT. We had this issue in a building I once worked in. Couldn't figure out why the AC wasn't removing moisture from the building. Turned out the "drains" were just a hole on the suction side of the fan. The water couldn't drain out due to the suction. Fix was to put a 6" long "J" shaped drain attached to the hole. The 6" of standing water overcame the fan suction and the water could drain out.)
It's certainly possible that when it rains, you have a higher relative humidity, and thus more moisture for the AC to remove from the TT air, and hence more water being held up by the vacuum I described above. But I don't see hard rain necessarily being worse than a light rain in this case (it would be the actual relative humidity, which isn't necessarily directly proportional to the rate of rain fall. Therefore, I'm still not convinced that you don't have an external leak on your AC unit above or at the roof. In fact, you seem to have improved the situation with your bolt tightening, which certainly makes the roof seal suspect.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
water
