Old 11-07-2019, 08:14 AM   #1
A/C fan always on
Just started last night. I have dual air conditioners on a Dometic digital control. The rear unit fan just started running constantly. It's set to auto, and the compressor isn't running with the fan. If I turn the power off it shuts off, but starts again with power on. Front unit is fine. Any insight would be appreciated.
2018 FR Sierra 5th wheel
nova73guy is offline   Reply With Quote
Old 11-07-2019, 10:29 AM   #2
Head Rambler
Do you have the Dometic LCD multizone thermostat?
If so, you may be able to initialize it. Try the procedure below and see if that helps.
Turn off the thermostat and press and hold the zone and mode buttons simultaneously. This will reset your thermostat.
Gotta go campin!
Old 11-07-2019, 06:57 PM   #3
I tried resetting the thermostat with no luck. Fan still runs continuously, even when the set temperature is higher than indicated. As far as I can tell the indicated temperature is correct.
Edit: interesting development. I set the thermostat lower and let the unit run through a cycle, and it seems to be working properly. I tried that before, but it only worked after the reset.
Old 11-08-2019, 09:03 AM   #4
Head Rambler
Maybe resetting it did some good. Only time will tell. I hope that solved your problems.
Gotta go campin!
Old 11-08-2019, 11:09 AM   #5
I'm hoping it works. So far so good. Thanks for the help!
fan
