Old 07-12-2015, 10:12 PM   #1
a/c help
OK folks I could use some help.....my TT has a 13.5k Coleman Mach air conditioner and I was wanting to install a soft/hard start cap so it would be easier to start with my generator both in higher elevations and warmer temps. So I thought I would contact the manufacture and get their recommendations on which cap to use on my particular model # and this is the reply from them. ''The model you have given was not manufactured with a start kit. The compressor on that AC is not rated for a start kit, so I canít recommend installing one.''......could any one tell me why this a/c is not rated for a start kit? (I did e-mail them with this question several days ago and they have not replied) what would happen if I installed one anyway would it damage the compressor? Or would it even do any good? This is the model # 48253c966 of the a/c. Thanks in advance for any help.
danc is offline   Reply With Quote
Old 07-12-2015, 10:40 PM   #2
KenHwy61's Avatar
Usually, an additional start capacitor is unnecessary with a properly operating compressor. They are sometimes added to compensate for low voltage or if the compressor won't start otherwise. Use caution in adding a start cap. If the compressor was not originally equipped and designed to operate with a start capacitor, the motor start winding will eventually burn out and ruin the compressor. This may be why the manufactuer says it is not recommended.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
