Old 03-20-2014, 03:37 PM   #1
jonrjen's Avatar
A/C Help, what just happened?
Just got back from a short outing and went to turn on the A/C. The fan goes to Automatic, which is fine, but when I go to set the temp it is reading I guess in Celsius rather than good ole redneck country Fahrenheit.
Now I can go to the net and Goggle an equation to make the C meet F, but I would sure like to know how to change the thermostat and keep things simple IE: the KISS Principal.
Can anyone assist me in doing so?
Thanks in advance,
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 03-20-2014, 03:44 PM   #2
Plain Old Member
There is a way to change it. I have the manual for it I downloaded a while back, bad thing is it's in the camper, where I'm not. I'm guessing you have the little square LCD Dometic t-stat. I'll dig around. Maybe somebody else has it and can beat me to it.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 03-20-2014, 03:47 PM   #3
Plain Old Member
Here you go. Page 6 I think.
Old 03-20-2014, 03:50 PM   #4
jonrjen's Avatar
Bingo, you hit the nail on the head with that solution.
Thank you so very much for the assist. This is what make the forum what it is............The MEMBERS!!!! MEMBERS just like you!!!!!
Old 03-20-2014, 03:56 PM   #5
Plain Old Member
Your welcome. Another thing you can check while you're playing around with it is the 1 or 2 degree temp differential setting. I have mine set on 2 degree where it won't cycle as much.
Old 03-20-2014, 04:19 PM   #6
jonrjen's Avatar
Thank you, I will do that.
