Old 04-03-2015, 06:57 PM   #1
Exclamation A/C issues in Palomini 133 RS
We have had our Palomini 133 RS for almost a year now. We spent 6 weeks camping all over last summer and we have some concerns about the A/C in it.
I was skeptical about the cabinet mounted 5000 btu unit in the first place but the rest of the rig is just what we wanted and everything else is fine.
As you can imagine the air isn't the coldest in Arizona in August, but we knew that, too...
The problem is the lack of a condensate drainage plan. We brought that up to our dealer in the begining and were assured that units drain fine...not!!
We have had it back five times to no avail. I have some ideas, but I don't want to void the one year warrantee, which I must admit has been honored 100% by our dealer. This last time they replaced all the water damaged cabinet and counter work inside the unit, but it still doesn't drain right and it will just happen again.
Has anyone had similar problems....AND found solutions???
Any thoughts would be appreciated...
HarryHogan is offline   Reply With Quote
Old 08-01-2015, 08:43 PM   #2
I was having a problem with drainage also Our camper didn't drain wate at all, not until we was going down the road then all the water drained into the camper. Dealer wasn't much help until I called Palomino myself and told them what was going on. Palomino called the dealer now the drainage problem is fixed sometimes you have to go over the dealer's head to get things fixed the right way. Good luck!
2005 GMC 2500HD Duramax Diesel w/430,000 and counting miles.
2002 Chevy Blazer chase vehicle
2015 Palomino Palomini 180FB
2001 Keystone Bobcat 289FBS
lstall00 is offline   Reply With Quote
