Old 05-08-2015, 08:13 PM   #11
Apparently my fan motor must be dead. Fan will not budge. After numerous attempts, and power off, power on, it started to smoke.
Fooltime is offline   Reply With Quote
Old 05-09-2015, 08:49 AM   #12
PhoneDude 8289's Avatar
Now that you let the smoke out it's time for a replacement. If you are near a motor shop and time permits you could get it rewound at a $$$ savings over a new motor.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-09-2015, 09:02 AM   #13
mud yapster's Avatar
New fan motor wouldn't cost much if you install yourself.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 05-09-2015, 10:15 AM   #14
I think a new one is around $110-120. I uust need to go back up and double check the numbers. I'm assuming that splicing will be required? I didnt see any 'plugs' at either end of the wires.
Old 05-09-2015, 02:18 PM   #15
Thumbs up fan not working on ac
I had same problem last year went up on roof and took cover off found that mud dupers made a nest which stop fan from turning cleaned it out and fan works fine:
kendochenetz is offline   Reply With Quote
Old 05-09-2015, 03:48 PM   #16
There is absolutely nothing in there. I wish there was. Fan is stopped solid. Cant even "muscle it" into motion.
Old 05-09-2015, 04:02 PM   #17
Vise grips on shaft and start working it back and forth, it will eventually break loose.
Old 05-09-2015, 04:22 PM   #18
There was a problem with some Dometic AC's a while back. You can get to the inside blower wheel from inside. Just drop the ceiling Assy. It's very easy to do . then, take out the screws holding the sheet metal plate you see above you that will expose the interior blower wheel. With the air turned off, spin the blower by hand, then try to turn on the ac. that should do it.
hillsdaletc is offline   Reply With Quote
Old 05-21-2015, 08:54 AM   #19
AC - no fan
I have a 25.5 2008 Lexington B+. We have not needed the ac in a while and when we tried to use it the fan did not work. After reviewing the comments on this forum, I checked the fan by taking the cover off on the roof. There were several dirt dauber nests that were keeping the fan from turning. After cleaning them out and rotating the fan, ac was back to work. This forum saved me a potentially expensive repair bill.
Rubaby is offline   Reply With Quote
fan, air conditioner
