Old 05-08-2015, 03:10 PM   #1
A/C on but no fan
I have a 2004 FR Rockwood 8285SS. The A/C worked fine last year. I turned it on for first time this year, and the a/c seems to come on, but no fan. I put it on fan only and you can here a click, but fan does not come on? Any ideas?
I have the Dometic single zone thermostat - less than one year old.
Fooltime is offline   Reply With Quote
Old 05-08-2015, 03:34 PM   #2
Brother Les's Avatar
Do you have the operating instructions to look over?
The fans are 12v fans, so you need a good battery power to it. clicking would seem to indict low 12v.
For the AC to work, you will also need good 110 power.
http://www.primetimerv.com/download/...structions.pdf
Brother Les
Old 05-08-2015, 03:38 PM   #3
Yes, thanks. I had just finished looking through that. (Of course I may have missed something). But the only thing I found close to my issue was the compressor time delay. That would make sense except the fan doesn't come on at all - even when set on fan only.
The battery is fully charged also. ( At least that's what my wall meter says).
Old 05-08-2015, 03:40 PM   #4
I have had this problem, the fan bearings were stuck to the shaft. I pulled out the filter and reached in and turned the fan with the power off. Turn on the power and the fan worked well for many years. I hope this helps
caesar101 is offline   Reply With Quote
Old 05-08-2015, 03:51 PM   #5
I had thought about that. My fan is under the cover on the roof. I had thought about some wd-40 or PB Blaster and a 'hand-cranking', because to me, that's what it sounds like. Like it is getting power but something is keeping the fan from turning. There is no debris under the cover (Leaves etc..)
Old 05-08-2015, 04:03 PM   #6
Oakman's Avatar
I used to have a similar problem when I owned a 2004 Wildcat. After the trailer sat in storage for the winter I would have to climb up on the roof, take the cover off the A/C and give the fan blade a quick spin. It would then work for the rest of the season. It helps to have someone inside to turn the A/C on when you spin the fan. I hope the solution to your problem is this simple.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-08-2015, 04:27 PM   #7
PhoneDude 8289's Avatar
Had that problem on a Cougar we once owned. Turned out to be a large wasp nest was built in the fan blades. After a good dose of wasp and hornet spray and a good cleaning all worked well.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-08-2015, 04:29 PM   #8
Don't believe the ac fan is 12V, I'm pretty sure it's 110V.
Old 05-08-2015, 04:34 PM   #9
TURBS's Avatar
It's 110v
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-08-2015, 04:34 PM   #10
I agree. I'm hoping for simple too. I'm getting ready to go up and spin shortly. As soon as my wife gets here to poosh the button.
fan, air conditioner
