04-19-2015, 12:50 PM
A/C only runs when plugged in, not on generator
I have a 2014 Coachmen Mirada 35BH. The A/C units will run when plugged into 50amp power, but is not running when the generator is running, Can anyone assist?
04-19-2015, 01:20 PM
How large is your generator? Are there any other 'Loads' being used on the generator while you are trying to start the AC?
This is what I have read about Wattage.
"Have a generator with at least 2,800 watts to jump start your rooftop air conditioner."
Brother Les
04-19-2015, 01:23 PM
Either generator too small, breaker on generator not on or auto-transfer switch not working properly.....
Fonzie
04-19-2015, 01:38 PM
The generator is 5500, so big enough to run everything. It was working running both ACs until this past week.
Phil
Tampa, Fl
04-19-2015, 01:40 PM
Should be a breaker on the top of generator. Could be flipped. ??
Russell
04-19-2015, 01:42 PM
Ok I will look for the breaker on top of the generator.
Phil
Tampa, Fl
04-19-2015, 03:13 PM
Ok. I checked the breakers at the generator and in the coach, no luck. Any other ideas?
04-19-2015, 03:32 PM
[QUOTE=FloridaPhil;839854]Ok. I checked the breakers at the generator and in the coach, no luck. Any other ideas?[/QUOT
i really hate using a gen, even for appliances, i usually run a good power bar before the plug
haven a blast
04-19-2015, 04:16 PM
i really hate using a gen, even for appliances, i usually run a good power bar before the plug[/QUOTE]
What is that supposed to mean?
Phil
Tampa, Fl
04-19-2015, 04:42 PM
[QUOTE=toslow;839869]
04-19-2015, 04:55 PM
Phil
Tampa, Fl
2014 Coachmen Mirada 35BH[/QUOTE]
dirty power, spikes constantly. at lest with a power bar there is some protection.
i know the stuff thats hard wired in can't be unplugged
haven a blast
04-19-2015, 05:04 PM
Phil
Tampa, Fl
i know the stuff thats hard wired in can't be unplugged[/QUOTE]
I'm just wondering how this ties into the original issue?
Dan
2014 Berkshire 390RB-60
04-19-2015, 05:07 PM
I'm just wondering how this ties into the original issue?[/QUOTE]
the OP speaks about a gen, i was just mentioning about how a jen is dirty power and could have created a bigger problem then just popping a breaker.
haven a blast
04-19-2015, 05:14 PM
If the generator is running properly it should not have power spikes. Is the AC the only think not working, is there power at the AC outlets?
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
04-19-2015, 05:19 PM
Thanks everyone. I figured out the problem. It was as simple as the coach power plug wasn't all the way pushed in. Haha
Phil
Tampa, Fl
