Old 06-23-2016, 07:00 PM   #1
A/C Problem
Blue ridge 3025 2014 RV -Bedroom A/C works normally ,main A/C trips RV circuit breaker after operating for 3 to 10 min. Most times the breaker will reset immediately and the A/C unit resumes. Seams like the hotter the outside temp the shorter the time the A/C remains on prior to tripping the breaker. Any ideas or feedback. Thanks.
sherylej is offline   Reply With Quote
Old 06-24-2016, 09:58 AM   #2
Head Rambler
Are you hooked to 50 amp service?
Is the main A/C a 15k BTUH unit? There have been problems with some of those units.
There have been several reports of people having to have them replaced. Myself included.
Gotta go campin!
Old 06-24-2016, 10:06 AM   #3
SeaDog's Avatar
I think I would start with checking the connections at the breaker and the AC to ensure they are tight. It may be a bad (weak) breaker. As BR said are you hooked to 50 amp?
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 06-24-2016, 10:27 AM   #4
Yes we are connected to 50 amp and I checked the connection also.
Old 06-24-2016, 10:51 AM   #5
Head Rambler
You could try replacing the breaker just to see if it's weak. That'd be easy to try before anything else. Especially since you've already checked the connections.
Gotta go campin!
Old 06-24-2016, 02:58 PM   #6
Good advice. Will try a new beaker switch. Thanks.
Old 06-24-2016, 03:37 PM   #7
SeaDog's Avatar
Let us know the outcome and what solved the problem
Retired Navy
Old 06-24-2016, 03:41 PM   #8
Iwannacamp's Avatar
It could also have a dirty condenser. That will cause excessive discharge pressure and increased amp draw.
If available. Check amp draw and confirm.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 06-27-2016, 12:45 PM   #9
Thank you all. The new circuit breaker worked. Finally found one at Home Depot after trying 2 rv parts departments.
Old 06-28-2016, 09:58 AM   #10
Head Rambler
Thanks for coming back and letting us know what fixed it. I'm glad it was as easy as a new breaker. A pretty easy fix as far as fixes go.
Gotta go campin!
