Originally Posted by Minthillbill
If you turn off by the thermostat and it shuts off, I suspect the thermostat is bad.
I was thinking that may be it, but was not sure. Reason being that the a/c has heat strips and when the correct zone is set for heat electric it works just fine.
It's only when using the a/c that the unit continues to cool even tho the temp setting has been met.
Also, the other zone works just fine.
Can 1 zone on the thermostat be faulty?
