Old 07-03-2015, 08:21 AM   #1
A/c won't come on in auto setting
My a/c had always worked well in the past. I have a 2014 Georgetown. I have a dometic thermostat. I set it to auto and it doesn't come on. All other settings work. Any ideas?
heidih is offline   Reply With Quote
Old 07-03-2015, 08:30 AM   #2
Mr. Dan's Avatar
Are you sure the air conditioner is working on the other settings - or just the fan?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 14
Old 07-03-2015, 08:32 AM   #3
Would I be correct to say it's working because when on other settings it's cooling very well? So yes, the air conditioner is working.
Old 07-03-2015, 09:41 AM   #4
Mr. Dan's Avatar
Beyond me then. Sorry.
Old 07-03-2015, 09:49 AM   #5
Learjet's Avatar
Is it the single digital stat? If so, going by memory,,,or look in your manual. Turn off the t-stat, then hold the "+" then the "on/off" at the same time for a few seconds until the thermostat resets to factory defaults
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 07-03-2015, 10:17 AM   #6
Thank you - I reset it and I did refer to manual. Your instructions were correct. However when in auto setting A/C still doesn't come on.
Old 07-03-2015, 01:02 PM   #7
Robbsails's Avatar
Frequently we have the same problem...I make sure it's on cool, then auto and if it still doesn't seem to work, I set the thermostat down low then see if it works!
Robbsails is offline   Reply With Quote
Old 07-04-2015, 12:25 PM   #8
Thank you. It just took awhile to cycle off because it was so hot. But it's working great.
Old 07-04-2015, 12:39 PM   #9
There's probably also a 5 minute timer on the AC, so it won't turn right back on, which is bad for the compressor. Timing is everything. You may have just tried Auto and the wrong time and manual at the right time.
2011 Traverse LT, 3.6L, FWD
Old 07-04-2015, 12:54 PM   #10
Gottawonder's Avatar
IF the Dometic thermostat unit has a clock in it, be sure and set the time. Been known to cause furnace issues in auto mode.
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
