Old 03-15-2015, 05:48 PM   #1
phat phrog stunt crew
a little schooling please
I discovered last season that my converter stopped working. As an upgrade, I have decided to go with progressive dynamics based on the user reviews on this site. Are these a sine wave type deal, a stepped sine or a modified sine wave. I gather a true sine wave is best from what I have read and what little I know about electricity. It will bite you and doesn't play well with water is the extent of my knowledge. Its coming up on camping season in my area and I want to be ready. Would a 60amp or 70 amp converter be better than what originally came in my sabre? The camper isn't close by so I am unsure exactly the model or output of the converter. Thanks in advance.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 03-15-2015, 06:12 PM   #2
caper's Avatar
You should not go down in amp but can go up the higher.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-15-2015, 06:15 PM   #3
RPAspey's Avatar
There are CONverters and INverters. INverters change DC (battery) voltage to AC (household 120 volts). CONverters take shore power (household 120 volt AC) to make DC to power your lights, radio, fans, etc AND it charges the batteries.
Going with a Progressive Dynamics converter is a wise decision. This converter uses plain old house power to make pure DC power.
First answer: When choosing a converter, there isn't a choice of sine waves as that is a choice when buying an inverter.
So, onto your Second question about amperage. If you aren't increasing your battery capacity, pick a PD converter closest to your old converter's output, but not less. More output isn't necessary for a stock set up.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-15-2015, 06:29 PM   #4
Thanks for the lessons. I knew somebody would be along shortly with good advice.
Old 03-15-2015, 06:33 PM   #5
I see amazon has a 70 amp converter for 212, and an 80 amp converter for less than 250. Thanks for the helpful info
