Old 01-30-2016, 05:47 PM   #21
R u sure it's the batteries? You may want to read my post "batteries draining"
2016 Rockwood Ultra Lite 2604WS
2004 Dodge Ram 2500 CTD 5 speed Manual 4x4 Laramie
2005 Ford Mustang Convertible
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 01-30-2016, 06:06 PM   #22
Tom48's Avatar
Originally Posted by dhatfield6 View Post
Skyline, are you saying that the wiring from the battery to the converter needed to be 4/0 awg?
He may have meant to say 4 ga as I think 4/0 (or is it 0/4) is like the size of awater pipe
My inverter can pull 200 amps at 12 v and I have fine performance on 2 ga from interter to battery with a run of only about 3 feet
Tom48 is offline   Reply With Quote
Old 01-30-2016, 06:19 PM   #23
Your right full battery will be 12.7 volts but if you check with the charger on, and the
battery is completely full charge, you will have 14.6 volts.
Still check all the ground on the system.
The factory never removed the paint before they install the motor or the ground wires to the frame.
Jonol is offline   Reply With Quote
Old 01-30-2016, 09:22 PM   #24
Nick M's Avatar
Almost right
If you are reading anything greater than 12.6 to 12.7 volts across the battery terminals then you are not reading battery voltage ----you are reading charger output voltage which should be 14.6 or 14.7.
Unhook the negative terminal and read across the battery terminals, as mentioned above resting battery voltage should be 12.6. More accurate is a specific gravity test.
I would tend to believe you have system voltage drop due to high resistance somewhere in your leveling system wiring, ground points are usually the typical culprit but not always. All terminals should be clean and tightly clamped. You should not be able to wiggle any wire termination.
If all this has been checked then your battery does not have the capacity to deliver the amount of current required by the leveling system. Do you know the dc current required to make the leveling system function properly? Is it within manufacturers specifications? If so then the likely problem is a defective battery - or - the battery is not sized properly to deliver the dc current required by the leveling system.
Good luck.
Nick, Sharon and Finnigan
Nick M is offline   Reply With Quote
Old 01-30-2016, 09:57 PM   #25
camaraderie's Avatar
X2...but you must wait 24 hours after unhooking to get a real voltage. The hydrometer reading may be taken immediately. Another way is to get a $20 load tester at Harbor Freight to take the surface charge off and then read voltage.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 01-31-2016, 08:07 AM   #26
Ddubya's Avatar
I am assuming that the level system does not work.
Mine will work with shore power on a battery with a dead cell. Check the connections. Some of mine were incorrectly crimped from the factory. Maybe it's time to look at the controller
Ddubya is offline   Reply With Quote
Old 01-31-2016, 08:27 AM   #27
Flybob's Avatar
I would take a hard look at the connections throughout the system. All it takes is one loose or corroded connection and it could cause the problem you are seeing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
battery, bent
