Old 10-09-2015, 04:50 PM   #1
Absorption Refigeerator
i have a a '73 Prowler we use as a guest room and in is a Magic Chef R 54 fridge. it works Great on prpane but electrical 110v heat strip is not working. i have an idea to put a projector bulb next to the chimney to make heat! the projector bulb is hot enough to give you 3rd degree burns real quick. is this maybe over kill, or any other ideas as i haven't found a source of spare parts.
Thank You, Two Toms
HotKreek is offline   Reply With Quote
Old 10-09-2015, 05:08 PM   #2
PhoneDude 8289's Avatar
Why not get a dorm size fridge for the "guest room". Home Depot or Lowe's for less than $125.00.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 10-09-2015, 06:50 PM   #3
Cajun Style's Avatar
Your heating element is a 135 Watts at 110 Volts, Just make sure both wires a black !
Very important!
Harry-O
Cajun Style is offline   Reply With Quote
Old 10-10-2015, 12:10 AM   #4
http://youtu.be/txqAHaTpexc
Harry-O
Old 10-10-2015, 12:22 AM   #5
http://www.amazon.com/Magic-Chef-671...eating+element
This should be your heating element
Harry-O
Old 10-10-2015, 04:51 AM   #6
I agree with PhoneDude that a small residential refrigerator is a very good solution since you will be using it with shore power. In addition to having more cooling capacity, the residential type refrigerator will use less than half the electricity that the RV refrigerator uses. Just be sure there's room for air to circulate around the external cooling coils. You'll have to close off the original refrigerator's outside openings.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
