Old 05-18-2012, 08:59 PM   #1
Steve Jackson
sideout1961's Avatar
AC
Dose the TT need to be connected to 30 amp to run AC or will it run plugged into a regular 110 outlet from home?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 05-18-2012, 09:03 PM   #2
sherdep's Avatar
13.5K or 15K AC unit? (13.5 maybe - 15K probably not)
You could try it - worse it does is pop the breaker - just dont try to restart the AC right away if the breaker pops.
I would plug the trailer in and let it charge the battery first so the converter doesnt draw more since it would be charging the battery versus trickle charging the battery
it would need to be on a 30 am circuit if you plan on running the TV and a bunch of accessories
depends on what amperage breaker you have it on - AC probably draws 12 to 15 amps on startup
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-18-2012, 09:11 PM   #3
sherdep's Avatar
I would turn off the breakers inside the camper off and only turn the AC Breaker on - to make sure nothing else is drawing.
Make sure you also use a large enough cord or get the ends that will convert your 30 amp cord to 110 plug
Old 05-18-2012, 09:13 PM   #4
The 13.5 on my current trailer and my past 2 trailers will run off a 20 amp circut at home with no problem Once the AC has started I have run the microwave as well.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 05-19-2012, 07:34 AM   #5
Steve Jackson
Thanks for the advise everyone. The reason I'm asking is we are taking the camper to the beach and I will only have access to 110. We won't really be using anything else in the camper it's going to just be for extra sleeping room cause the house isn't big enough for everyone.
Old 05-19-2012, 02:55 PM   #6
bikendan's Avatar
unless you're in Florida, why would you need a/c at the beach?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 05-19-2012, 03:59 PM   #7
backin15's Avatar
Mine runs fine as long as the water heater isn't on electric.
backin15 is offline   Reply With Quote
Old 05-19-2012, 04:47 PM   #8
BicycleMark's Avatar
If your AC is 13.5 BTU/Hr then you should be able to run from 20 amp service just fine. Make sure you have a hard start capacitor on the AC and make sure your water heater is is switched off for elec.
Have fun at the beach!
BicycleMark is offline   Reply With Quote
Old 05-19-2012, 08:18 PM   #9
Steve Jackson
Bikendan:Summers in July up in New England get quite humid even on the beach.
Old 05-19-2012, 09:53 PM   #10
bikendan's Avatar
agree with BicycleMark, if it's a 13.5k a/c, then a 20amp should run it, as long as the WH and fridge are on propane, not electric.
