Old 06-05-2016, 02:10 AM   #11
bob dirt's Avatar
Originally Posted by boondocking View Post
OP says it hums, but does not start.
Yep, that's what he says, but he also says it won 't shut off till he shuts off breaker....that leads me to believe it is actually running which will sound
like it's humming. If it was a bad capacitor, it would shut itself off due to overload on or in compressor....just say'n
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 06-05-2016, 06:02 AM   #12
mark0224's Avatar
Maybe I have not stated right if I turn the fan to on or auto and turn the breaker on it starts blowing cold air. But if you turn it off compressor continues to hum fan stops.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-05-2016, 02:19 PM   #13
bob dirt's Avatar
Are you going to try and fix yourself or is it in warranty? What state are you from?
Old 06-05-2016, 10:28 PM   #14
mark0224's Avatar
Going to start with the basics t stat and a relay i found could be the problem when i googled the problem. If looking at those doesn't come up with a result I will probably have somebody look at it.
Old 06-06-2016, 03:16 PM   #15
mark0224's Avatar
Think I got it figured out, as others have said I believe its the control board. I put the old analog t stat in and it still did it , found the compressor relay on the board and unhooked it and it didn't happen anymore. that relay is supposed to be a normally open so I believe its the problem.
Old 06-17-2016, 03:38 PM   #16
mark0224's Avatar
Thanks all for the input replaced the compressor relay control board today and everything seems to be working right so far. Came with new digital thermostat and an updated digital board. Less wires, not a lot of instructions only downfall.
Old 06-17-2016, 03:49 PM   #17
Mr. Dan's Avatar
Thanks for reporting back with the solution to your problem. This reporting back helps our members!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-17-2016, 05:02 PM   #18
mark0224's Avatar
I know and glad to help others, and was really glad I could fix it myself.
Old 06-18-2016, 08:40 AM   #19
mark0224's Avatar
Old control that came out of my ac unit
Old 06-18-2016, 08:43 AM   #20
mark0224's Avatar
New control all wired in tested while still all open . Be careful while electric is live if you test like this.
