Old 05-14-2016, 06:23 PM   #1
TsnTexas's Avatar
AC hard start capacitor
I'm looking to hook up a hard start capacitor, but having trouble figuring out which one I need. I have a Coleman Model # 48254C869. Can anyone point me in the right direction?
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 05-14-2016, 07:44 PM   #2
Supco HS6 (SPP6) Hard Start Capacitor would be the one to get.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 05-14-2016, 07:51 PM   #3
I go RV'ing not Camping
jgourlie's Avatar
Ditto
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 05-14-2016, 08:14 PM   #4
Who Dares, Wins
doc73's Avatar
Yet, picked mine up off amazon.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-14-2016, 11:54 PM   #5
HONDAMAN174's Avatar
Yep. Me too- same one. FWIW I even keep an extra one in case another camper needs help.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 05-15-2016, 12:15 PM   #6
rsdata's Avatar
here is my write up w pics on doing the deed...
Installing hard start cap on 13.5 Coleman AC unit
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 05-15-2016, 03:39 PM   #7
TsnTexas's Avatar
Fantastic, thanks for the advice and especially the tutorial. It sounds like this capacitor is pretty generic as a one size fits (most) all solution. My champion 3100 will start the AC so long as I turn everything off first which is a pain. So I figure a little help from the additional kick will increase it's overall life. Now the trick will be to know which is the run capacitor. I think the manual has the diagram.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 05-15-2016, 03:55 PM   #8
rsdata's Avatar
When I took off the cover to the AC, the electrical drawing was on the inside of the cover... no guess work.
2014 Shamrock 183
Old 05-16-2016, 11:01 AM   #9
nodrawers's Avatar
I run a 2011 13.5 with a WH2000i with no problem. Works great.
Hello Thomas,
Thank you for your inquiry and your interest in our EasyStart products. EasyStart is perfectly suited for your Coleman Mach 13.5k system powered by a Honda EU2000i. In fact, weíve done extensive testing with the Honda EU2000i generator, and we know that it will start any 115V air conditioner on the market from ECO mode. That will be key for your being able to run overnight on one tank of gas.
The model EasyStart that you need is ASY-364-X36. You can view it on our website at this link, and purchase it in our webstore at this link. There are generic wiring diagrams on our website, but we can assist you further with your specific system. If you send a photo of your wiring diagram, we can edit it and show you exactly where the EasyStart connects.
To help you figure out the wiring on your own if you would rather do that, it turns out Coleman-Mach manufactured a 15k rooftop system specifically meant for applications in Australia, and they built in EasyStart in their factory in Kansas. Attached is a wiring diagram of that system which shows the EasyStartís 4-wire connections.
Please let us know if you have any further questions. Thank you again for your interest and business.
Micro-Air Webstore Administration
webstore@microair.net
Micro-Air, Inc.
124 Route 526
Allentown, NJ 08501
609-259-2636
Micro-Air
store.microair.net
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 05-16-2016, 11:44 AM   #10
Georgia Frog Rally 2018
aceinspp's Avatar
Would like to see a little more detail for install as I'm not an electrician. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
