Old 05-28-2017, 10:46 PM   #1
Ac/ heater issue
Getting an E1 flickering code, I unplugged everything and plugged everything back in. I still got the flickering code but it got faster. Any idea how to clear this code so I can get my heat on
Freshcup is offline   Reply With Quote
Old 05-28-2017, 11:00 PM   #2
crunchman12001's Avatar
Does your thermostat manual have a reset procedure?
2015 F-250 FX4
Old 05-28-2017, 11:02 PM   #3
I don't see one
Old 05-28-2017, 11:12 PM   #4
You do not have a manual or it does not contain a reset procedure?
Can you post a pic or model number of your thermostat?
Is this a new trailer, pop up or MH? Has it worked correctly before or is this the first time you have used it?
2015 F-250 FX4
Old 05-28-2017, 11:17 PM   #5
Here you go...
https://www.aberdeenhomerepair.com/s...tton-p2582.php
If you install the thermostat and it still acts up, then perform a system initialization by following these steps:
Press and hold the '+' button.
Press and hold the 'On/Off Mode' button.
Hold both buttons down for about three seconds until the screen shows a -- --.
Release both buttons and press the 'On/Off Mode' button again to turn system off.
Press 'On/Off Mode' to turn back on. The thermostat has now been reset.
2015 F-250 FX4
Old 05-28-2017, 11:17 PM   #6
Old 05-28-2017, 11:21 PM   #7
Does that help
Old 05-28-2017, 11:24 PM   #8
yes. Did you try the reset I posted above?
2015 F-250 FX4
Old 05-28-2017, 11:31 PM   #9
Didn't work
Old 05-28-2017, 11:34 PM   #10
You said you unplugged everything? Did you unplug the shore power and disconnect the battery?
You said the reset did not work? Did you get the -- -- ?
You turned it back on and still get a E1?
Has the furnace / thermostat ever work properly before?
2015 F-250 FX4
heater
