Old 07-21-2014, 07:03 PM   #1
AC not blowing cold air
Just bought a 2014 Stealth Toy Hauler - used, everything worked until I got it home. Now the AC doesn't blow cold air. Tried shoreline power and generator, neither power source works. Talked to a service center and it takes 2 weeks for them to look at it. They said it sounded like the compressor's start module? $100 part and an hours labor, just have to leave it there for 2 weeks. Any suggestions?
Thanks,
Steve & Kristine
2009 Silverado 2500HD
sanderss is offline   Reply With Quote
Old 07-21-2014, 07:12 PM   #2
Plain Old Member
If it's a Dometic AC, you can contact them directly, as it will be them that ultimately pays for it. You don't have to go through dealer or Forest River for components like that. It's under warranty, utilize it. If you don't already know of a mobile tech, Dometic will try to find one and you can have them come to you to fix it. You'll have to pay for the service call itself, but usually that's a LOT cheaper than fuel and aggravation to bring it to a dealer.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-21-2014, 07:14 PM   #3
Herk7769's Avatar
Thanks,
Steve & Kristine
Sounds like they have no idea what is wrong with it.
A start capacitor does not cost anywhere near that much and there are just a couple of screws and 3 or 4 spade connectors involved.
The big silver can with all the wires coming out the top is what they are talking about. A shop hour is anywhere from 100 to 250 dollars.
Arrgh.
What model AC do you have?
rv air conditioner capacitor | eBay
Caps run from 11 bucks to about 40 bucks depending on the model needed.
Heck, while you are in there put a hard start capacitor and a fan delay relay in so you can run your AC on a Honda 2000.
ID:	58635   Click image for larger version
ID:	58636   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-21-2014, 07:16 PM   #4
Plain Old Member
Just seen it was your first post. Welcome to the Forum. Check out the brand specific section for your model. Sometimes you can get some great feedback and help.
Stealth - Forest River Forums
Old 07-21-2014, 07:20 PM   #5
dcheatwood's Avatar
Welcome. Watch how quick you get your answer. This place is great.
2018 Forester 3011 DS
Old 07-22-2014, 10:47 PM   #6
I have a 2014 Sandpiper. We bought it last September, so we didn't really use the AC until this summer. During our first above 90 degree camping trip, we noticed that the camper would not cool down very well. We have two Dometic AC's. Luckily a friend camping with me has an AC business, so he had some equipment to fix it with him. It turns out that both AC's were not fully charged with 410a freon. He had a tapping screw that could tap into the sealed system to add the freon. The rear AC showed no sign of a leak, but the front AC had a small film of oil on the evaporator that could indicate a leak. I know I probably voided my warranty, but as hot as it was, I didn't care. The bottom line is they were both not fully charged and only blowing 5 degrees cooler than the intake. After charging them to the proper amount, they would blow about 22 degrees cooler than the intake or return air.
cwleczyk is offline   Reply With Quote
