02-18-2019, 08:58 PM
#21
Trailer Park Supervisor
That is why it is so important to have the right size A/C for the space it is cooling. Too small and it won't keep space cool. Too large, and it won't cycle often enough to keep the space dehumidified.
Yes, I drink the water!
02-18-2019, 09:07 PM
#22
02-18-2019, 09:11 PM
#23
Difficult to do. It's oversized for a humid Florida winter but maybe not for an Arizona summer. Of course, I don't intend to go to either place in the summer.
02-18-2019, 09:22 PM
#24
Air Conditioners are basically dehumidifiers that vent heat and moisture to the great outdoors. Air Conditioners do dehumidify. If they did not, all of us living in the south would be up to our elbows in mildew and black mold because the humidity was not lowered.
02-18-2019, 09:31 PM
#25
Location: Chicago, Rochester now GA/SC at Lake Hartwell
Ft. Pierce Florida today reached 89 degrees and 87 percent. Camper was at 72 all day with 33 percent humidity. The camper is surrounded by condensate water. We have a Siberian Husky inside...gotta keep her comfy. Two 15K ac units. One cycles...the other runs continuously.
2019 Sandpiper 379FLOK, F350 Lariat 6.7 DRW, KN4YBP APRS, NRA Benefactors.
02-18-2019, 09:36 PM
#26
FWIW: I found the Dometic Ceiling A/C in my Coachmen was not cycling properly because it has its thermostat internal in the unit, rather than a remote wall-mounted style. On maximum cold it would cycle the compressor off at about 77 degrees, so it was never on long enough to dehumidify. I installed a remote thermostat and that cured the problem. Another trick to enhance the dehumidification is to use the heater to raise the temperature into the low 80's, then switch to A/C. The higher temperature allows more efficient removal of humidity.
02-19-2019, 09:25 AM
#27
When it comes to sizing there is not much to choose from . most problems are from improper installations or poor design of the controls and where they are located .
02-19-2019, 09:48 AM
#28
For what it's worth, If you have a multi speed fan running the Fan on low it will remove more moisture from the air.
On low the coils get colder and the air passes thru the AC unit slower allowing more moisture to be removed.
The compressor runs at the same speed only the fan changes speed on the low setting.
02-19-2019, 09:54 AM
#29
Good thoughts jwfrede! We are in Florida fighting the same issue. I finally figured out the problem and it was exactly what you said. It took me a day but I eventually got it. Heading out for a dehumidifier today. I am sure that will make all well. Thanks for the nice write up.
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
02-19-2019, 10:10 AM
#30
Did you install the remote unit yourself? If so what remote did you install and how difficult was it? If you paid an RV place how much was it, if you don't mind my asking?
