Old 05-21-2015, 12:11 PM   #1
AC only cycles off briefly
The main AC unit will cycle off only about 30 secs to a minute. I think the compressor may cycle off slightly longer than the fan. It has done this even when outside temp was in the 70's. Did not know if the thermostat being located up in the hall outside the front bedroom was causing the temp to fluctuate rapidly as soon as the fan cycled off. Just curious if anyone else has experienced this.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 05-21-2015, 12:55 PM   #2
Phat Phrog Stunt Crew
elind's Avatar
Mine does the same thing. I believe it's the fan changing speeds when you have it on AUTO fan. When you select the fan mode you will LO AU HI. When you have it on the AU mode it will cycle back and forth between HI & LO and stops in between to reset.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-25-2015, 10:19 PM   #3
This weekend paid closer attention to fan speed and believe that is the case
Steven & Tiffany
