Old 07-15-2014, 10:17 PM   #1
B and B's Avatar
AC Roof Leak 8289 WS
We found a roof leak out with the RV the past 4 days. Drips from the front of the AC grill, intake side. This only happened when we had rain. Took out the arid filter grill. Found the foam gasket was not compressed in the centre. The wood was warped somewhat.
A added blocking at both the left side and smaller at the right side, The pressure of the gasket holds the blocks in place.
This compressed the gasket enough to provide a good seal. No water leaking with a hose pointed at the front of the unit.
Tightened the front bolts that where loose, I also ty-wrapped the cables up out of the way for the freeze sensor, AC supply and the control to the thermostat.
ID:	58275   Click image for larger version
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-20-2014, 06:44 PM   #2
Looks like the weld didn't hold on the aluminum framework. If in fact it is cracked, could this have caused enough flex to help create a leak? Hard to tell in the photo if it has failed.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
Old 07-21-2014, 07:59 AM   #3
B and B's Avatar
The weld is solid, just sloppy work. They drop the frame in this spot for cable chase to the roof. I can figure out why, one of my questions in Goshen to the techs.
Sent from my Z30 using Forest River Forums mobile app
leak, roo, roof
