Old 08-08-2016, 09:49 AM   #1
Kenny kustom's Avatar
Ac turning off
This week, my ac has been shutting off. The fan stops.
If I cycle it off, then back on.. it cuts back in. Runs for a bit, then off.
If I leave it after it shuts down, it will come back on, after about an hour or so.
Any ideas??
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 08-08-2016, 09:55 AM   #2
Flybob's Avatar
What is the voltage ?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 08-08-2016, 10:03 AM   #3
116 ish.
I'm home now, and plugged into 30 amp on the side of my house.
119v. Still doing it.
2016 Sabre 36QBOK
Old 08-08-2016, 10:44 AM   #4
Head Rambler
What brand of A/C do you have?
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-08-2016, 12:06 PM   #5
Dometic.
I'm doing yard work today, I've left it on, and it's shutting off and turning on by itself.
2016 Sabre 36QBOK
Old 08-08-2016, 12:50 PM   #6
What temp is set? It will shut off if fan is in auto and it reaches temp set on stat.
AGFazio is offline   Reply With Quote
Old 08-08-2016, 02:07 PM   #7
It's set really low.
The fan has never shut off before, just cycled the compressor.
2016 Sabre 36QBOK
Old 08-08-2016, 02:16 PM   #8
Witch Doctor's Avatar
2016 Sabre 36QBOK
What you have is described is if your fan is set to on, then only the compressor will cycle. in auto mode the fan should cycle with the compressor. Do I understand you correctly Kenny? Also if your sensor in the fin is not set correctly you could be freezing up then when it thaws it comes back on. You could be getting a false reading. Dometic has those both pronounced problems to start with.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-08-2016, 02:20 PM   #9
Does it seem to be cooling?
Is it satisfying the t/stat?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-08-2016, 05:13 PM   #10
I performed a " master reset " as per the dealer.
It seems to be operating correctly now!!
I went through, and can activate the functions individually as per the diag mode.
Name:	ImageUploadedByForest River Forums1470694369.124535.jpg
2016 Sabre 36QBOK
