Old 07-26-2016, 07:13 PM   #11
I reckecked and it is still in the coils where I placed it. Thst apparently helped as I only had to open the downdraft once on a four day trip in 100 degree heat with no shade.
Perhaps the original poster should check this as well.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 07-27-2016, 07:31 PM   #12
Too Tall's Avatar
IMO, you have a thermostat problem. Most AC units have separate relays for compressor and fan. It would be very odd to have intermittent issues with both.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 07-28-2016, 12:20 AM   #13
It's a dometic brand AC unit. Oddly enough, since posting this the issue has stopped but I'm not confident it won't start again since it has done it once before.
I too find it odd that the setting the switch to on, the fan doesn't work. That would take the AC unit out as a possible cause since the fan should still run without the AC running.
Frost is offline   Reply With Quote
Old 07-28-2016, 09:51 AM   #14
the last post mentioned a freeze sensor. we were having intermittent problems with our a/c and it turned out to be a damaged freeze sensor up in the a/c unit. we were also getting error codes (E5 if I remember) on the thermostat. technician replaced the freeze sensor and all has been good.
CHICKDOE is online now   Reply With Quote
Old 07-28-2016, 01:32 PM   #15
Witch Doctor's Avatar
That's right, what it is doing is energizing your fan wire, once you do that it sends the power to the fan relay in the unit that pulls the contactor or relay in. If the unit is running normal now, just try the fan in the on position and see if it will come on. If it won't come on it would be either the stat or the contactor relay in the unit, I don't know much about Dometic but there should be a board that the wire hooks to which will pass it to the relay. At that time if it didn't come on then jumper the red and either green or blue wire at the stat that will by-pass the stat. If it's still not coming on then it would be the board or relay(might all be one) If it comes on when jumpered then it's the stat, if not the board. Intermittent problems are hard to fine, so you need a plan when you catch it. My money is on the board, but they are costly$$$$. So you want to make sure, learned here on the forum that Dometic uses the negative wire for there units. Did HVAC most my life and never heard of that before, that's why I don't like dometic, there the only unit that is wired like that. Hope your problem stays away them damn little gremlins.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
