Old 05-16-2015, 01:30 PM   #11
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
If the fan on the AC is working,,,,the circuit breakers are OK,,,,,,it's going to be something other than that.
Grampa Jim is offline   Reply With Quote
Old 05-16-2015, 02:18 PM   #12
Witch Doctor's Avatar
This is true, Your internal over load could be open on the compressor. It has to cool to reset. If the blower comes on and doesn't trip the breaker.
1) Off on internal overlaod/ cause short cycle low on freon
2) bad start and run capacitor
3) Contactor not pulling in on all legs
4) short in yellow wire from stat
5) low voltage
It could take 24 hrs to reset internal overload depending how hot it got, What you can do to shorten that period is to place a bag of ice on the dome of the compressor. If your compressor was shorted out between the windindings you would pop your breaker everytime. Just some idea's for you to check..
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-16-2015, 03:01 PM   #13
dcheatwood's Avatar
Check inside breakers. Not fuses.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-16-2015, 03:26 PM   #14
if you have a Dometic a/c, heat control call the factory on reseting the control . ive done that with mine to get to work
Big Bill is offline   Reply With Quote
Old 05-16-2015, 04:48 PM   #15
The blower is working so it is getting 110v....
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-16-2015, 08:37 PM   #16
BurgPath's Avatar
Tried the full power down. No change. When on auto it does nothing. Have to switch to ON to get fan to run. All breakers toggled, no change.
If the ac was dead would that stop the furnace from working? Furnace won't come on either.
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 05-17-2015, 04:22 AM   #17
No it should not, If your fan is coming on when you put it fan on then you have power to the stat. It sounds like your stat went. If you stuck and need A/C, shut the power off 110v and disconnect 12v. Pull your cover off the stat add a jumper between RC and Yellow wires. That would bring your A/C on, but it would stay on until you remove that jumper. Your subase that i'm talking about just acts as a switch. Depending on the circuit base you might need to add the green for the fan but I doubt it. The circuit board in the
A/C should take care of that, bringing the blower on. Hope I did not confuse you. You can also try and jumper red to white, to see if the Fau will come on. If all this works it will be the stat itself, which could mean either the subase or control. Either way you will need a new one. Any battery operated stat should work get one from HD or Lowes. You can look up how to wire it on this forum many threads. Or PM me....Good Luck.. If you had a set of alligator clips much easier to do. IMO everyone should carry a set in there RV tool box's. They come in handy.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-17-2015, 05:11 PM   #18
BurgPath's Avatar
Thanks for the help everyone. Never really needed the AC, got lucky. Was a cool enough weekend that a fan was all we needed.
Will tackle this next weekend.
Look up Rock Island State Park in TN for a nice weekend trip. Lots of hiking and some amazing waterfalls.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 05-22-2015, 05:49 PM   #19
BurgPath's Avatar
Finally got to test this.
Jumpered the thermostat on low and the AC came on and ran like it should.
Woohoo!
Bad thermostat!
Now to find a replacement.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 05-22-2015, 06:10 PM   #20
BurgPath's Avatar
Based on what I've read, this thermostat will work.
Honeywell Digital Non-Programmable Thermostat-RTH111B - The Home Depot
Thoughts?
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
