Old 06-05-2016, 06:42 PM   #1
AC will not turn off.
I have 2 AC's and the one in the bedroom will not turn off unless I hit the breaker. It doesn't blow air but it runs even if temperature is reached and the off setting doesn't turn it off either. What should I do?
OswegoLion is offline   Reply With Quote
Old 06-05-2016, 07:40 PM   #2
Head Rambler
Are you saying that the compressor is running, but the fan shuts off?
If so, you most likely have either a bad thermostat or control board.
It would help if we knew what unit and thermostat you have.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 06-05-2016, 07:46 PM   #3
Bluepill's Avatar
1. If it is a digital thermostat, disconnect the power wire (usually red) for 10 minutes to reboot the microprocessor. Then reconnect and see if problem is solved.
2. If above doesn't work, disconnect the compressor control wire at the thermostat (usually yellow) and see if that shuts off the compressor. If so, probably a bad thermostat.
2008 Itasca Meridian 37H
Old 08-15-2016, 08:51 PM   #4
CWG
Did you find out what was causing your problem with your bedroom AC? Mine is now doing the exact same thing with the bedroom AC.
CWG is offline   Reply With Quote
Old 08-16-2016, 09:49 AM   #5
Head Rambler
CWG -- The OP shows online, but hasn't responded to our request for info. So, either they've gotten it fixed and aren't interested in letting us know, or they've lost connection with this thread.
Tell us which A/C unit and thermostat you have and maybe we can help.
If you have a newer dometic digital thermostat, you may be able to initialize it and get it back working.
P.S. You could try PMing the OP and see if they'll respond.
Gotta go campin!
Old 08-16-2016, 03:22 PM   #6
CWG
Hi Bama Rambler,
I have the newer dometic thermostat and dual roof AC units. Any advise would be appreciated.
Thank you
2017 Columbus Compass 340RKC
2003 GMC Seirra 2500HD 4x4 Duramax
Old 08-16-2016, 03:55 PM   #7
Head Rambler
There's an initialization sequence in the manual for resetting it.
But, here is the snippet of it.
To do a system reset:
• Make sure the CCC 2 thermostat is in the OFF mode.
• Simultaneously press the MODE and ZONE buttons. The LCD will display “IniT” and all available zones.
• Release the MODE and ZONE buttons.
• Press the ON/OFF button to exit system set up.
Make sure the unit displays both zones when it's initializing. If it doesn't, there's a communication problem with the zone that's not displayed.
Gotta go campin!
Old 08-16-2016, 05:22 PM   #8
CWG
Thank you Bama Rambler,
I just gave it a try as you suggested and still no change. AC and fan both run good but I can only shut them down by switching off the breaker.
Regards
Old 08-16-2016, 08:24 PM   #9
A/C not shutting off in bedroom
"I have 2 AC's and the one in the bedroom will not turn off unless I hit the breaker. It doesn't blow air but it runs even if temperature is reached and the off setting doesn't turn it off either. What should I do?"
Is it the compressor or the fan?
The reason I ask is you can set the fan to run independently from A/C operation, even with the furnace on.
Check this:
From the control panel select the zone the bedroom is on.
Go to fan and see if it is set to auto/high or low.
Anything other than auto will keep the fan running all the time even if the set point has been reached.
You have independent control of both set of fans in zone 1 and zone 2.
Also note that when the unit is approaching set point on auto, it will slow down the fan speed. When it does, it will cycle off the fan for 3-5 seconds and then restart on the lower speed.
Hope this helps.....
Randyman64 is offline   Reply With Quote
Old 08-17-2016, 10:41 AM   #10
Head Rambler
If it isn't as Randy suggested, it sounds like you have a thermostat and/or control box issue.
Gotta go campin!
