Originally Posted by ChristyK
Thank you! This is one of the ideas my husband put out last night. This may sound sad, but we couldn't remember how many outlets are usually on the pedestal for each camping spot. ? (We've been in cabins for a while.)
Usually 2 or 3. On a 50amp site, you'll get a 50, 30, and 15. On a 30amp site, you'll get a 30 and 15. BUT- not always.
I'm actually planning on adding a bunch of outlets to my current camper. If I had space to add a breaker, I was going to drop a line down from it into the under belly. Instead, I have to tap into an existing electrical outlet (replace it, add a box, and add extra cables off of it) and down into the under belly.
I'll then run back to the walls where I want the outlets underneath of the camper. I'll use surface-mount wiremold to get up to the height that I want the outlet and then surface-mount boxes for the outlets themselves.
My intention is to just use Romex for the runs. I know that stranded is better, but RVs do just fine with Romex now. I will use stranded to get electric into a slide, but that's because that portion actually DOES move.
Given the usage you described, it all seems fairly minor. A computer + monitor doesn't take much. Running a space heater or something with high electrical requirements is a different story.
