Old 12-21-2015, 09:57 PM   #1
Forester Fred's Avatar
Add on speaker for bedroom TV
My rig has a smaller Furion TV in the bedroom which is nice except the audio sucks. It's tinny and hard to understand. I tried changing the audio settings on the TV setup menu and nothing really changes.
Has anyone added on external speakers to their TV and if so, what type/make/model?
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 12-21-2015, 10:03 PM   #2
sgtlm17's Avatar
I would think you could add a sound bar found at most big stores. I have one at home and it makes the sound amazing.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 12-26-2015, 09:46 AM   #3
Connect a Bluetooth transmitter to TV and buy a small Bluetooth speaker.cheap on ebay
old rv man is offline   Reply With Quote
Old 12-26-2015, 10:35 AM   #4
I did this. Mounted two speakers in ceiling above headboard.
Name:	Trailer speakers.jpg
Name:	Trailer speakers1.jpg
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 12-26-2015, 12:29 PM   #5
BooBoo23's Avatar
X2 DW doesn't like the sound from the TV so I got a Bluetooth transmitter and a Bluetooth sound bar and put it behind the sofa. no wiring except to plug in the power for the speaker. Just make sure you get a transmitter and not a receiver for the TV.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 12-26-2015, 01:37 PM   #6
Bought a Vizio sound bar from Walmart for around $50. No installation required. Plugged it into wall outlet and connected wire from sound bar to headphone connection on TV. Sound is great.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 12-26-2015, 04:06 PM   #7
I searched a bit and found that Furrion actually makes a soundbar for the TV, it's only around $60 so I might go that route. Although, I like what you guys did with the speakers mounted under the cabinet. That would work good over the head of the bed as there's an overhead cabinet there. Maybe extend a headphone jack down my side of the bed so I can use earspuds without bother the wife!
Skip & Deb
Old 01-02-2016, 07:17 PM   #8
You may want to check the soundbar, some residential units I've seen have an earphone out jack so you can plug into that, and it kills the sound output of the soundbar. for private listening.
Calgary, AB Canada
Ridenfun is offline   Reply With Quote
Old 01-06-2016, 08:32 PM   #9
Jimmerinwi's Avatar
If the Furrion sound on the tv sucks, what makes you think the sound bar made by the same company will sound better? I would go with a better brand, Vizio , LG, Samsung. Even if it's a few more bucks, in the end you might be happier.
Somedays I wake up Grumpy, somedays I just let her sleep......(Ray Scott)
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
bed, roo
