Old 05-10-2015, 08:49 AM   #1
Adding 2nd AC?
New Dude in Bama,
I have a 2014 40' Sandpiper, and want to add a second AC over the BR.
Any suggestions of how to proceed?
Blurose2 is offline   Reply With Quote
Old 05-10-2015, 04:43 PM   #2
RETIRED
n-e-d's Avatar
Welcome to the forum. You may want to go the the main page and scroll down to the Tech section or your trailer specific section under Trailers and 5th wheels
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "Red Rover"
n-e-d is offline   Reply With Quote
Old 05-11-2015, 12:11 AM   #3
check your fuse panel to see if you have a breaker labeled for a second ac. If you do the wire is beside the vent in the other room. If you don't see a electrical box take a screwdriver and remove the trim ring around the vent in the inside. The wire might be in a box beside the vent inside the ceiling. Once you find the wire adding the ac is easy just remove the vent and follow the instructions with the new ac. It mounts using the same hole the the vent was in.
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-14-2015, 11:32 PM   #4
1l243's Avatar
If you don't have a breaker in your panel for a second AC then it is likely that your not prewired. If your not prewired it would make a 2nd AC installation much more complicated. In that case you may consider a Fantastic Fan ...
Clink on this link and then scroll down till you get to my second AC install. It should give you some ideas of what's involved..
RV.Net Open Roads Forum: What did you do to your Toy Hauler today???
1l243 is offline   Reply With Quote
Old 05-15-2015, 06:12 AM   #5
TURBS's Avatar
Originally Posted by Blurose2 View Post
New Dude in Bama,
Is the unit 50amp?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-15-2015, 07:15 AM   #6
muddyrode's Avatar
Is your unit pre wired for a second AC mine is.
I have a blank plate in the bed room ceiling next to the roof vent, that is where the wiring is for the second AC is
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 05-15-2015, 10:14 AM   #7
1l243's Avatar
Turbs has a good point if your rig is 50amp you can be wired for a second AC does not mean that it is but if your 30amp then not much chance...
Old 05-15-2015, 10:24 AM   #8
TURBS's Avatar
Right.
TURBS
Old 05-15-2015, 10:35 AM   #9
Oaklevel's Avatar
Well Yes & No................
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-15-2015, 10:41 AM   #10
1l243's Avatar
I have seen 30amps with two AC's but setup so you can only run one at a time....
