Originally Posted by 510Rick
Hello Everyone , I am embarking on helping a friend add an AC unit to a really cool 1978 Aristocrat TT . We do a lot of horse trading between us and help each other with just about all of our projects usually one of us is more knowledgeable then the other but on this project neither of us knows quite what to do .lol. I'm Pretty sure we can cut the hole in the roof and get it mounted but neither of us are too sure how to wire the thing up . We were thinking dedicated cord from the ac to be plugged in directly to power outlet (generator/wall) . Or would we be better off trying to add it to the existing electrical system . I feel like adding it to electrical system probably wouldn't work since the TT wasn't spec'd for AC and we were hoping not to have to repace any of the stuff in there since it all works perfectly . I'm hoping someone here could shed some light on this install for us . Thanks in advance ,Rick
How many amp service is your TT? I assume 30.
Do you already have an air conditioner?
Do you have an available space on your breaker box?
I'm not familiar with how electrical was done back then. I would assume similar as today with a main breaker panel, but who knows.
Ideally, I would wire to camper's breaker box.
Do you know how the roof is constructed? The air conditioner hole needs to be 14"x14" and requires a square "frame" between the roof and ceiling to prevent crushing. Is there an existing hole (normally occupied by a vent) that you will use?
I recently installed a 3rd air conditioner - where there was no hole, wiring or frame - so I can help with the process.
The big unknown is the roof truss construction and spacing. You'll want to figure that out before cutting a hole in the roof.
