Old 06-25-2015, 07:14 PM   #1
Who Dares, Wins
doc73's Avatar
Adding hard start capacitor
So I am thinking of adding the hard start capacitor to my Domestic 13,500 AC. I was thinking of using the SPP6 capacitor to help with the start up on my gene.
I only have one capacitor for the AC and the fan. I am guessing I would just add the capacitor in parallel to the red and white wires on the A/C side. Just want to run this past the smarter people than me to make sure I am good. Pics of the wiring and current capacitor...
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-25-2015, 07:45 PM   #2
HONDAMAN174's Avatar
Yep. I see two extra terminals on the red side and one extra on the white. Party on Garth!
Just glad to get away
Old 06-25-2015, 07:50 PM   #3
Witch Doctor's Avatar
yep that is correct....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 06-25-2015, 07:51 PM   #4
Who Dares, Wins
doc73's Avatar
Yes there is indeed one terminal hiding under the white wires. Thanks for your confirmations.
2015 ChevyHD D-Max
Old 06-25-2015, 08:27 PM   #5
Man. You guys have good eyes. Even after Hondaman noted the white side I had to look 3 times to see that little guy hiding under there.
rana is offline   Reply With Quote
Old 06-25-2015, 09:08 PM   #6
rsdata's Avatar
I would make a drawing of the cap connections (or a cell phone pic or two) for reference then unhook it and take it to an electric motor place. Near Cincinnati we have a place called A-1 Electric. Granger may carry them also. Show it to them and get a larger value cap and hook it up. This looks to be a multi-value cap... more then one internal cap value. Just get one with larger values... the cap may double in size but would be easier then adding another cap in parallel... IMO
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 06-26-2015, 07:46 AM   #7
It is compressor and also fan capacitor. You need to be careful increasing the Megs it could cause a problem. A plug in hard start is the best way to do that but just my opinion especially on run capacitors.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-26-2015, 09:37 AM   #8
rsdata's Avatar
I tend to agree with gljurczyk above...
I have bought used motors and compressors that would not start for pennies on the dollar only to fix them with a new cap sized not much larger than the originally installed size. With a quick google you can find a sizing chart for the amount of uF (micro farads) that you should use for specifically sized motors and compressors. There is a range of sizes that you can use. You may just want to try another cap the same size or just lightly larger and you might find that the one you have now is weak (leaky).
2014 Shamrock 183
Old 06-26-2015, 12:18 PM   #9
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Don't go more than 10% of the MFD rating for the motor you're working on. Never go less than the factory rating.
Grampa Jim is offline   Reply With Quote
Old 06-26-2015, 12:28 PM   #10
Iwannacamp's Avatar
X2 on the 10% rule... it's in stone somewhere. I wouldn't go toooo big on the start cap either.... it's a "plug and play" deal to add the start assist kit. Plug to the c/com terminal... and the herm/compressor terminal on the run cap... stay away from the fan terminal.
Iwannacamp is online now   Reply With Quote
