Old 05-14-2014, 06:10 PM   #21
mark0224's Avatar
Originally Posted by dcogs15 View Post
I also had interference with the Wingman in the down position. I posted the solution I used on our RV in April, 2013 under "Reverse Wingman installation".
Still wouldn't work would hang over the side then could catch on something. Anyway already ordered the other.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-14-2014, 06:11 PM   #22
Freds342's Avatar
Originally Posted by raoulwv View Post
That's kinda what I'm thinking too. Have you tested both? Since the Jack replacement head is under $40 right now, I'm thinking of buying it just to do an A-B comparison. If nothing else, I'll have a backup antenna.
SCVJeff is a Broadcast Engineer, and has access to a 75-Ohm Spectrum Analyzer.
He tested both, and the Winegard won hands down in all catagories, but it really shined in the VHF arena.
You can search for his comparison at RV.net in the Technology Corner threads.
It has been hashed and re-hashed over there.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 05-14-2014, 09:51 PM   #23
Wingman and "the bat" has bigger driving elements. They are the same design concept, a yagi type. Jack would also have less gain because its encased in plastic.
Wingman can be made of coat hangers for seasonal campers, just add more elements to make it more sensitive to fringe signals, but would make it more directional. More "ribs" added to the design, more distant stations could be received. 20$ ebay "HD yagi antenna" will outperform the wingman 10 times. Again, for seasonal campers.
Kuba is offline   Reply With Quote
Old 05-15-2014, 02:23 AM   #24
Witch Doctor's Avatar
Originally Posted by mark0224 View Post
Ordered the Jack antenna will be here tomorrow hope its as good as you all say. I know it can't be any worse than the batwing i have on this trailer.
If you put your jack on you will get atleast 3x's the stations. Also the range is further. You will need to point the flat end to the tower for reception. I use to get 3 stations with my old wingman in my driveway, now I get like 12 or 15. The distance to the tower is about 112 miles away in Roanoke Va. and I live in Clarksville Va. I get NBC,ABC,CBS and Fox and also a bunch of garbage to. I will not go back to my old batman winegard. I was told by the Rockwood Rep. at the plant that they are looking into installing all jacks on new units. Where ever I camp people always ask how many stations am I pulling in and it is always double of there's and they get sold on it immediately. I had a wingman on my old trailer but could not use 1 on the rockwood due to it hung over the side. I have a big empty roof and they choose to place it on the edge 6" in. So I had to go with the jack, and now I'm very happy with it.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-15-2014, 09:30 AM   #25
mark0224's Avatar
My old trailers wingman worked great but when I looked at this newer one it didn't look as well built or nearly as heavy. With the old one I could get 25 to 30 channels out of our driveway getting channels as far away as 70 miles but this one 10 miles is a struggle. Will see this weekend when I get to install the Jack. I may be just wasting time and money but some learn from mistakes if it doesn't work will be looking a new amplifier. As is everything appears to be ok on that.
Old 05-15-2014, 11:10 AM   #26
I think you will be very happy, shoot me a pm when you get it installed, should take about 10 mins....
Old 05-16-2014, 11:35 AM   #27
mark0224's Avatar
Got the Jack antenna delivered today will have to wait till tomorrow to see how it works as it is raining today. It came with an amplifier so if the one in the trailer is bad I'm covered there to check if it still doesn't work.
Old 05-16-2014, 03:21 PM   #28
That's great, got 5" of rain here yesterday. Let me know how it works as I said I'm pushing FR to install them.....
Old 05-16-2014, 10:46 PM   #29
Freds342's Avatar
IF one lives in an area where the preponderance of stations are broadcast on UHF Channels, the Jack will work fairly well. The Jack is totally inferior to the "REAL" Winegard with the Wingman. It's simple physics.
You need more antenna to receive the VHF channels than the Jack can handle.
I'm very happy for the people who get more channels than they did before, but did they really troubleshoot, or did they 'Easter Egg" the problem, and replace a perfectly good antenna due to a bad, or loose, connection?
I spent 30 years of my life trying to make small, stealthy, antennae with gain.
It doesn't happen without major losses in signal that cannot be made up for with amplifiers. You can't take a poor signal and make it better with an amplifier that also adds noise to the signal.
I'm signing out of this discussion with disgust.
But: Forest River is right if they stay with the crank-up vs. the omni radome. The Jack is fine if you live in an all UHF area.
I don't!
But I had many successes in my career, including many of the systems used on satellites, stealth aircraft, and military drones.
Old 05-17-2014, 10:41 AM   #30
mark0224's Avatar
Took my Batwing off today and installed the Jack antenna, before couldn't get even get local channels , now picking up channels 75 miles away. I don't think it was the antenna alone because when I took it off it was full of water, can't see where it's broke anywhere but water got in it some how. Going to replace roof top cable also just because it's covering looks like it's going to crack soon, i usually replace them about every 5 yrs just because they have no protection from weather.
antenna
